1.8L 2ZR-FXE install into a 2009 Prius.
Discussion in 'Gen 2 Prius Technical Discussion' started by black_jmyntrn, Jun 1, 2025.
  1. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    Tell me why you think it wont work... then tell me why you think it will work... I wanted to go for more.. like a 2.5 or 2.4 but the whole sticking to the same overall system voltage per engine has me limited without swapping out the entire system.
    oh and i've gotten as far as...
    The main issue with putting a Gen 4 Prius engine into a Gen 2 is the crankshaft and camshaft timing signal. Even though the Gen 4 sensors have the same tooth count (36-2), the signal they output is different — voltage, timing, and waveform don’t match what the Gen 2 ECU expects. Because of that, the Gen 2 ECU can’t sync timing properly and won’t run the engine unless it gets the exact signal it’s designed for.
    That said, most of the other sensors (injectors, coils, throttle, etc.) can be reused from the Gen 2 and installed onto the Gen 4 engine, or adapted pretty easily. So really, this crank/cam signal is the only real barrier to making the swap work with the Gen 2 ECU. If we can convert the Gen 4 sensor signal to match Gen 2 specs, or swap in Gen 2 timing wheels and sensors, everything else should fall into place.
    all other that's needed is a simple for the most part to resolve with a 3D scanner and certified accurate digital calipers.
    #1 black_jmyntrn, Jun 1, 2025
  2. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    The Gen 4 engine has an electrical engine water pump. The Gen 2 has a mechanically driven pump. How are you going to control an electrical engine water pump in the Gen 2?
    #2 Brian1954, Jun 2, 2025
  3. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    That’s exactly where the magic of a 3D scanner and CAD software comes into play. The idea is to create a custom bracket that mounts a Gen 2 mechanical water pump in the same location as the Gen 4’s electric water pump. Once you’ve got that alignment right, all you need is to route a serpentine belt properly — which is definitely doable with some pulley alignment and tension adjustment.
    It’s not about controlling the Gen 4 electric pump — it’s about adapting the mechanical one so the Gen 2 ECU can keep doing what it was designed for, without a hitch.
  4. PriuSocal
    PriuSocal Member
    289
    52
    SoCal
    wow bro @black_jmyntrn props to you and all that tinkering with the prius…I thought the prius was a tesla at first lol.
    Keep it up, I am curious to see the outcome of your ideas.
    black_jmyntrn likes this.
