Independent Prius specialist in Boston area?
Discussion in 'Gen 3 Prius Main Forum' started by E2E, Feb 7, 2024.
  1. E2E
    E2E Junior Member
    Boston
    2014 Prius v wagon
    My wife's 2014 Prius V has the cold start knock for a few seconds. My local mechanic is great for most things, but has never done a Prius head gasket.
    Looking for a non-dealer recommendation in Boston area.
    Help!
  2. Tombukt2
    13,226
    2,392
    Maybe get some opinions and some things like that and you're in a cold area and barking up a tree that you may not want to attempt to climb maybe I don't know I certainly wouldn't. Or couldn't bring myself to do so knowing what I know now not an option we'll be costly You may not get the money back out of the vehicle at all.
  3. Mendel Leisk
    41,785
    What’s the miles on it?
    To avoid another blown head gasket, be sure to get the EGR system, including EGR passages in the intake manifold, thoroughly cleaned. See first two links in my signature (on a phone turn it landscape to see signature).
    With the EGR cleaning , there’s precious few professionals doing a decent job. Dealership service departments are clueless, will tell you it’s not needed, won’t “stoop” to cleaning, just replace parts (at least a grand for parts, before labour).
    DIY cleaning costs next to nothing, takes a day or two, or ask your regular mechanic to take it on; it’s not too involved.
    #3 Mendel Leisk, Feb 8, 2024
  4. ASRDogman
    ASRDogman Senior Member
    7,724
    3,960
    It is no different than any other Internal Combustion Engine.
    Are you certain it's a head gasket?
    What is the mileage? Is the coolant tank low? Have you had a pressure test?
    Quick changes in temps could cause moisture to form in the intake manifold which
    will also cause some knocking. And shutting the engine off before it's warmed up on
    a cold start can cause it the next time it's started sometimes.
  5. Mendel Leisk
    41,785
    Yeah consider leak-down test, or boroscope inspection of combustion chambers, preferably with coolant system pressurized, to accelerate coolant leakage into cylinder (the usual failure mode).
  6. bisco
    52,229
    Leo and sons comes recommended, I haven’t tried them.
    Leosons.com
  7. TWrecks99
    TWrecks99 Junior Member
    22
    MA
    Did you get it fixed? Where? How much? I have a 2012 PriusV with the same issue, Leo & Sons quoted $4500 over the phone, seems high.
  8. Tombukt2
    13,226
    2,392
    4500 for what head gasket ? If all not sussed out it will fail again in pretty short order so beware. getting it all sorted properly is about a 5K endeavor usually . There have been some fly by night operators trying to condense these operations and streamline the process and hasn't been proved to be effective . Beware again
  9. bisco
    52,229
    that is a quote for what did you tell them, cold start knock?
  10. TWrecks99
    22
    MA
    I told them new head gasket. The local mechanic saw coolant in the oil. It's had the cold start knock for a year, various fixes were tried (new intake manifold, egr, coils, plugs). Noticed the coolant was dropping down the last 6 months, have added 1 gal in 6 months. Also gurgling in the heater core during cold start.
    I need to email them for a formal estimate.
  11. Brian1954
    Brian1954 Senior Member
    2,351
    948
    South Central PA, USA
    Replacing the head gasket in the engine will not last very long. You need to have the engine replaced because you waited too long to get it fixed.
  12. ASRDogman
    7,724
    3,960
    It's likely the head is warped now. So you are looking at a new engine, or remanufactured one.
  13. TWrecks99
    22
    MA
    Not sure I understand. If they replace the failing gasket and machine the heads, won't it be good? It runs well after the start. Doesn't overheat. Not rough start every time.
  14. Brian1954
    2,351
    948
    The block might be warped, or you could have a bent rod. If you can not DIY, it is not worth the risk to pay someone to just replace the head gasket. You will have a better solution if you replace the whole engine.
  15. bettergolf
    bettergolf Active Member
    493
    369
    Sanford NC
    Don't let these guys scare you......you are correct a warped head can be machined or replaced. If all that other stuff that "might be" happening is there, they will let you know. And normally a head doesn't warp if the engine has not been overheating.....Normally when a G3 Prius head gasket is leaking the coolant goes into the combustion chamber, not the oil....this is what causes the rattling noise.
  16. ASRDogman
    7,724
    3,960
    Depends on how much they have to shave off the head. They are not thick enough to shave
    munch off. They weren't designed to be machined....
    Who knows, you might get lucky....
  17. Tombukt2
    13,226
    2,392
    If you started to pound on those rods they start to bend the tops of Pistons don't ride tdc correctly anymore then bam usually lots faster than a year . It's a mess . Happened right here . Twice so yeah buck up. It's a lot of fun especially for folks with no understanding of internal combustion engines . And the like . But yes you can do anything ya like . .
  18. TWrecks99
    22
    MA
    Shops says about $8K for an engine replacement as used engines are hard to find and may have same issues. I see the JDM engines on ebay for $1500, are there restrictions in MA for install a non-US engine?
  19. bisco
    52,229
    not that i am aware of. you may want to check with the rmv for smog inspection requirements
  20. bettergolf
    493
    369
    Sanford NC
    Find another shop....no way is it that much.
