Prius C led Headlights Customization
Discussion in 'Prius c Technical Discussion' started by Roger2689, Jun 12, 2025.
  1. Roger2689
    Roger2689 Junior Member
    South Africa
    2019 Prius c
    I own a 2019 prius C with the Led Headlights. I wanted to know if there is a plug and play mod to let's say have the led drl to be of another color similar mod to what the new Corolla has . I took out the headlights to have a better understand where the led is located and i can have a mod or in the event the led goes bad I'd know how to replace it. So far i haven't seen anything about this led board. Any leads or help is highly appreciated. Thanks
  2. Leadfoot J. McCoalroller
    8,013
    7,492
    Pennsylvania
    2018 Prius c
    if you search for 'JDM Toyota Aqua' parts you may find what you want. Might also be useful to use the body code NHP10.
    You'll want to look for ones meant for the 2018-2019 version of the car.
    Good luck!
    Roger2689 likes this.
  3. Roger2689
    South Africa
    2019 Prius c
    Thank you mate
