Screeching noise when idling in hot weather
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Audiodoc, Jun 12, 2025.
  1. Audiodoc
    Audiodoc New Member
    Charlotte, NC
    After sitting a couple minutes idling in hot weather a constant high pitched whine/screach comes from under the car. When I move the shifter into Neutral it stops.
  2. saneesh8
    saneesh8 Member
    208
    52
    Allen, TX
    With A/C on? try without A/C and see if it changes. If still happens with A/C off, check coolant valve or Inverter pump. Google it. Inverter pump easy to check. No big red triangle so far? Also does it sound from driver side wheel well area? It could be the coolant pump, if so, it is noisy. usually turns on only when you turn off the car to pump the coolant into the storage tank.
  3. Tombukt2
    13,270
    2,396
    Or honk type sound ? Car is fully warmed up . Sitting Ready correct,?
  4. PriusCamper
    PriusCamper Senior Member
    12,982
    5,278
    Pacific Northwest, USA
    Pretty common for the HVAC system to make all kinds of weird noise in a near 20 year old Prius... As long as it keeps working, don't worry about it.
    saneesh8 likes this.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,774
    831
    Southern California
    Turn off the A/C. Does it stop? Wouldn't make sense for a shift to Neutral to stop the A/C from making a noise.
    Only under the car? If the OP opens the hood where in the engine compartment is loudest? Something rubbing on one of the fans, or a failing fan motor, might screech. Doesn't really make sense that shifting to neutral would stop it in this case either.
    Very odd that shifting to neutral would silence it. Seems like it might be prudent to put a stethoscope or other listening device on the bottom of the transmission, maybe even a finger would do if the sound generates enough vibration to feel. If that is where the sound is coming from check the ATF level ASAP. There is no dipstick, the car has to be jacked up or put on a lift and a finger stuck in the fill hole after the bolt is removed.
  6. Tombukt2
    13,270
    2,396
    The blow off valve on the bottom of the compressor is overfilled.. usually you see yellow dye rt under this spot under compressor.
  7. Audiodoc
    Audiodoc New Member
    Charlotte, NC
    Thanks for all the theories. Finally got to my Prius Whisperer mechanic. Put it on a lift and wiggled all the exhaust pipes around and found a joint that was leaking. Took it apart, Put Loctite on, tightened the bolts and it was cured. Freaking exhaust leak that sounded totally mechanical. By the way he didn't charge me anything. Sometimes life is good.
