2025 Prius Wish-List
Discussion in 'Gen 5 Prius Main Forum' started by PriusPeep, Apr 26, 2024.
  1. Gokhan
    Gokhan Senior Member
    6,561
    2,618
    Paramount CA
    Toyota dealers are the best places to get OEM tires because they include a free-replacement road-hazard warranty. You get a brand-new tire even if there is a repairable puncture. So, it is fine as long as you don’t bother with tire stores or online tire retailers.
    otatrant likes this.
  2. hill
    8,938
    You can get the same perks from Costco & Discount Tire as well. Difference being you don't have to pay the overpriced stealership fees that enable the center to send their kids through an ivy league university.
    we'll stick w/ Costco & Discount Tire - but thanks for the suggestion tho
    #82 hill, Jun 12, 2025
    purplePriii and otatrant like this.
  3. AgentPTFC
    AgentPTFC Member
    59
    40
    PNW
    2025 Prius Plug-in
    XSE Premium
    Adding to the list I would like:
    -better resolution cameras
    -power adjusting front passenger. Seems like an odd omittion, especially for the the top trims.
  4. Gokhan
    6,561
    2,618
    Paramount CA
    OK, but the concern was that no one other than the Toyota dealers carried the 19" tires.
  5. GeoJ
    GeoJ Active Member
    218
    198
    United States
    2023 Prius Prime
    XSE
    If you are referencing my concern it was not that no one other than Toyota dealers carry the 19". My concern was that there are only three (I think) tire options in the 19" (the OEM Toyo and Michelin, and a snow tire Michelin-Ice). It is an odd tire size, that is the problem.
    #85 GeoJ, Jun 13, 2025
    Trollbait likes this.
  6. Gokhan
    6,561
    2,618
    Paramount CA
    Nevertheless, I still think that the Toyota dealers is a better deal for your buck than discount online or brick-and-mortar stores. Mounting, balancing, disposal, and environmental fees are completely included in the price, and the road-hazard warranty is a replacement with a brand-new tire rather than puncture repair.
    Toyota Tire Center—Prius 19" tire at Penske Toyota
    Toyota Tire Center—Homepage
    And I checked Costco mentioned by @hill. Free tire rotations is a good perk. However, the tire they claim to carry (Michelin Primacy All-Season) is out of stock, which was my concern with non-Toyota-dealer tire retailers for Gen 5 Prius.
    https://tires.costco.com/SearchResultsByVehicle?Year=2025&Make=Toyota&Model=Prius&Option=Limited&size=19
    #86 Gokhan, Jun 13, 2025
  7. Winston Smith
    Winston Smith Active Member
    410
    286
    OH
    2024 Prius
    LE AWD-e
    Far be it from me to tell Toyota how to market cars, but some products are marketed in a way other than as it comes on the showroom floor. Harley Davidson has a catalogue of engine modifications to make your bike louder and faster because that's how customers want it.
    Seems as if Toyota could offer a Normal Human Option that would include 17" wheels and a spare with a jack.
    Tande likes this.
  8. Gokhan
    6,561
    2,618
    Paramount CA
    The 17" wheel is already offered on the base trims, and you get the aero wheel covers with them as an added bonus. If you want a higher trim, chances are over 90% that you want the better-looking 19" wheel as well.
    Spare tires are disappearing from most cars, not just Toyotas.
  9. Winston Smith
    410
    286
    OH
    2024 Prius
    LE AWD-e
    It wasn't so in my case; I specifically avoided higher trims that were more common when I was looking because I didn't want a larger screen and wheels. The complaints about the 19" wheel size, tire size, durability, efficiency and selection aren't hard to find.
    Yes. An option would remedy that problem.
  10. GeoJ
    GeoJ Active Member
    218
    198
    United States
    2023 Prius Prime
    XSE
    Regarding spare tires disappearing, whether this is an issue depends, I think, in large part on where you drive. If you are mostly in cities, urban/suburban areas, and also more local, it is probably ok. On the other hand, if you drive in rural isolated areas, and add to that where weather is not mild, I have some concerns.
    Gokhan likes this.
  11. Winston Smith
    410
    286
    OH
    2024 Prius
    LE AWD-e
    A cellular out of range of a tower isn't going to help you call for service.
  12. Trollbait
    12,691
    Thus why the car comes with a spare in markets were cell coverage and road quality is a concern.
  13. Paul Gregory
    Paul Gregory Senior Member
    2,247
    595
    Alberta
    2024 Prius Prime
    XSE
    I wish there could be an app that makes better use of the system and the sensors.
    It could show the RPMs of the various components in the drivetrain.
    It could also show the distance to the vehicle ahead, instead of just a symbol.
    But it likely won't happen; Toyota would sue them into the stone age.
  14. douglasjre
    douglasjre Senior Member
    2,206
    737
    Null, NL
    What stops you from using thicker tires?
  15. douglasjre
    2,206
    737
    Null, NL
    Maybe this is your warning sign that you need to lose weight(y)
  16. douglasjre
    2,206
    737
    Null, NL
    Get JBL club speakers
  17. douglasjre
    2,206
    737
    Null, NL
    Is the bolt pattern on the 5th gen rim the same as bolt pattern on the 4th and the 3rd gen rims?
  18. Hammersmith
    Hammersmith Senior Member
    2,329
    2,387
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No. Gen3 and 4 use 5x100mm. Gen5 uses 5x114.3mm.
  19. PriusCamper
    PriusCamper Senior Member
    13,104
    5,311
    Pacific Northwest, USA
    Actually there are apps that help with that... Get a OBD2 bluetooth reader and there's all kinds of apps that help you fine tune the data coming from your Prius.
    For example, every time I'm on a road trip in my Gen2 and I'm heading into the mountains I open up Car Scanner (ELM) app to use the tachometer screen to ensure most efficient engine speed at 3500rpm because how fast you should go when climbing up a steep grade is not easy to discern without that data...
  20. Gokhan
    6,561
    2,618
    Paramount CA
    3,500 rpm sounds too high for efficiency.
    There are at least two efficiency factors, one being thermal efficiency and the other being aerodynamic efficiency. The slower you go is obviously the better for the latter. The thermal efficiently is also maximized at lower rpms, as low as 1,300 rpm and no more than 3,200 rpm.
    https://www.researchgate.net/figure/Complete-BTE-map-generated-from-Toyotas-publicly-released-map-images-of-its-2016-25L_fig20_332155862
    otatrant and VelvetFoot like this.
