2008 Toyota Prius, EV/Electrical issues, Looking for Help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Greenhouse89, Jun 12, 2025.
  1. Greenhouse89
    Greenhouse89 New Member
    Usa
    SE
    I got this car back in 2019 and it ran great for a few months, but has been an electrical nightmare for the last year. It started with the key fob no longer opening my door when I was near, I have to put the key fob in the car to get it to start, and the speedometer and electronic dash cluster needs to be replaced, so it will just completely stop working until I reset the battery. My AC will also refuse to work for days or weeks at a time and seemingly at random, start working again, and I have a fan in the back passenger seat that is on full blast and cannot be turned off.
    The EV battery has had the cells tested and refilled 5 or 6 times in the last few years, but have become a real problem in the last couple of weeks. I took the car to Auto Zone and did the check engine light plug-in and got: P0301, C1241, C1259, and C1310. My dad also has a Prius, a newer model, and has been having similar issues with misfires recently, so I had him take a look and we changed the spark plugs. I'm still getting the misfire detected. He recommended changing the caps too, but I just can't afford them right now. Would that even be worth doing at this point, or a waste of money?
    This Prius is my daily driver, I am the only bread winner currently and I am near broke. Every time I drive the car, it feels worse. The entire dashboard lights up with almost every warning light and the red triangle of doom every time I turn it on. Half the time I have to shut the car completely off at a stop light because if I drive it too long, it won't shift, which is a recent development. Then, last night, it wouldn't stop accelerating. When I hit the break, the car felt weird, I could feel it accelerating and trying to break simultaneously. I was keeping pace with a guy on the highway going 51 MPH and I didn't have my foot on the gas or the break.
    So as of right now, what are my best options? Do I take it to Toyota, have them replace the battery with an auto loan or outright sell it and try and buy something else? Is it even safe to drive at this point? I have access to the bus near my apartment, but I work late often, so I can't get a bus back home, plus it's 2-3 hour walk and my knees aren't in the best shape. I'm stressin' out. Thank you for you consideration and help if you made it this far.
  2. Tombukt2
    12,136
    2,144
    What part of the country are you in this car in. It fo.nsie difference. You have a lot going on and not slot to work with it seems . Do you have basic wal.mart tools n such or do you try n stay away from tools ? .
  3. Brian1954
    Brian1954 Senior Member
    1,747
    681
    South Central PA, USA
    How many miles on the car?
    Based on the trouble codes that you posted, you have at least two separate problems with the car besides the dashboard problem.
    The P0301 is a misfire in cylinder #1. That is one of the problems.
    The second problem is with the hybrid system in the car. The C1259 and C1310 codes are telling you that there is at least one trouble code being reported by the hybrid control system, but the Auto Zone scanner was not good enough to give you the code. So, you need a better scanner that is capable of communicating with the hybrid control system to find out what the trouble code is. Based on your description that the hybrid battery cooling fan is running at full speed. My guess is that you have a problem with the hybrid battery.
    You stated, "The EV battery has had the cells tested and refilled 5 or 6 times in the last few years, ........". What do you mean by "refilled," and who did the work on the hybrid battery?
    Depending on how many miles you have on the car, your best option may be to sell it and get a replacement vehicle.
  4. Tombukt2
    12,136
    2,144
    If it needs a battery it needs it. Another car with a battery when it wears out it will need replacement this will never end .
  5. Greenhouse89
    Usa
    SE
    I'm in Western Washington, near Bremerton. I have some tools, but my Dad is a mechanic of sorts so he has torque wrenches and a myriad of ratchets and other tools, he works on his own cars, but money is my biggest problem right now.
  6. Greenhouse89
    Usa
    SE
    Just under 300k. Would changing the caps on the spark plugs fix the misfires? My father found a certified technician to open up the hybrid battery, he's a Ukrainian guy, the first 2 times I had issues with the battery, I went to him and it worked better for about a year each time. But the last time I took it to him he said the battery cells were fine, which was over a year ago.
  7. Brian1954
    1,747
    681
    With 300k miles, I would think that it is not worth trying to fix the car. You have at least three problems with the car.
    1. The dashboard does not work correctly.
    2. P0301 misfire.
    3. Probably an issue with the hybrid battery again.
    If you could fix it by yourself, it might be worth it. If you need to pay someone to fix it, it is time to sell it as is and move on to a different car.
