Question-2025 Prius in EV Mode: Reply quickly!
Discussion in 'Gen 5 Prius Technical Discussion' started by iRun26.2, Jun 13, 2025.
Tags:
  1. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    I hit a deer and totaled my 2012 Prius Plug-in. It was a great car! 197K miles total. I loved driving in pure EV mode!
    I can’t go long without a car so I have a down payment on a 2025 Prius PHEV. Looking at the manual, worries me a bit because it almost seems like the car won’t work on EV mode above 30 mph. I want the same car I had but with this new, bigger battery (and advanced features like the solar roof)!
    I’m willing to accelerate slowly and minimize speeds to 55mph? Can I truly get by with only plugging in (no gas) for weeks? I once got 2250 miles on one tank of gas (charging up to 15 miles) in my 2012 unit.
    I see the dealer to buy it tomorrow. I think I’ll get it but I’m nervous about not getting EV when I want it. I hate it when the gas engine turns on! Please respond with your opinion tonight if possible. I’m under the gun. :)
  2. Brian1954
    Brian1954 Senior Member
    2,187
    855
    South Central PA, USA
    You want the plug-in hybrid version of the Gen 5 Prius, not the hybrid version. They are two completely different cars. Make sure you are looking at the correct manual.
    #2 Brian1954, Jun 13, 2025
  3. RX808
    RX808 New Member
    29
    17
    2025 Prius Plug-in
    XSE Premium
    Prius PHEV (used to be 'Prime') is what you'll be shopping for if you want to drive around in EV - up to 84mph.
  4. bisco
    51,893
    it will be better than your 2012 in every respect except size. you are misinterpreting the manual.
    it won't spin the engine at 55mph like your 2012, and you will be able to accelerate faster on ev only than your 2012, and you even get a heat pump, so you don't have to freeze without the engine running.
    all the best!
    BiomedO1 likes this.
  5. BiomedO1
    3,560
    1,846
    SacTown, Ca
    Don't know where your getting your information from; but it's way off!! Even my gen4 can get up to 80+mph without spinning the ICE. The gen5 is suppose to get 40 miles in EV alone. You'll find it accelerates a lot faster than your 2012; but it's a larger and heavier car. You won't get 40 miles in EV if your speeding down the expressway - but you will if you drive normally.
    IMHO, If you can live without the advanced tech features, save some money and don't get them. They tend to be buggy at best, more junk that breaks down and requires repairs.
    Good Luck and find better more accurate sources of information....
    PrimeDan likes this.
  6. iRun26.2
    824
    169
    United States
    I’m
    Mmm
    Sorry, I got mixed up with the nomenclature. I know what I’m getting (and what I need) is the plug-in hybrid electric vehicle.
  7. iRun26.2
    824
    169
    United States
    Maybe I was reading the wrong manual! I don’t recall anything about a heat pump. That’s awesome! I sure missed than in my old plug-in Prius. I live in Minnesota so the winters are cold. I’m sure the temperatures will force the gas motor on (much to my displeasure).
  8. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    The solar roof is a waste of money in my opinion. It's much too small to be much good.
  9. iRun26.2
    824
    169
    United States
    Well, I am an engineer and I get excited about new toys. The solar panel roof is the thing I want the most. I hate giving up the efficiency of the car for the expensive options.
    The solar roof will probably never pay for itself but it simply seems super exciting.
    I lost track where I was reading the manual. I bet I was reading the wrong one.
    bisco and RX808 like this.
  10. iRun26.2
    824
    169
    United States
    You are probably right (it being a waste of energy). I simply want it to try it out. It will be fun to try this out under various conditions.
  11. BiomedO1
    3,560
    1,846
    SacTown, Ca
    They've been heat pumps since the gen4s; but that isn't going to cut it in Minnesota. If you don't mind freezing and hoping your seat heater can melt through your winter jacket. I believe the ICE will stay off until it get down below 20F, but your going to burn a good chunk of your EV battery and won't make it to the 40 mile marker doing that.
  12. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Wouldn't it be cheaper to bolt bull horns to the hood?
  13. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I was concerned about the heat pump as well, but I made it through the winter here with temperatures as low as -25C and no problems at all.
  14. iRun26.2
    824
    169
    United States
    Now that is amazing! Thank you for posting that.
  15. iRun26.2
    824
    169
    United States
    (Sorry, I don’t get it)
  16. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    For excitement.
  17. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I don't know if this is relevant, but I put a sheet of cardboard between the outer grill and ahead of the upright support ahead of the radiator, leaving about a 3" gap. I left it in all through last summer, and never had a cooling problem. The engine coolant temp never goes above 90C.
  18. ChapmanF
    18,146
    I have a solar-roof gen 3, where the roof didn't do anything but run the cabin blower to keep the cabin from being an oven in hot weather. Kind of gimmicky (tho' I admit I've gotten spoiled by coming back to a ventilated cabin).
    But five years ago I modified it to also keep the 12-volt battery charged, and I've been very happy with that. Five years without worrying about leaving the car for too long, or having any kind of starting issue (except that one time I left the dome light on for the length of a conference). If I'm camping I can leave the car with the fridge in it and the solar watthours mostly cover it.
    The gen 3 panel puts out 60 watts max. What's the rating of the gen 5?
  19. iRun26.2
    824
    169
    United States
    Here’s the address
    They quote the 2025 version as being 185W.
  20. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I have admit, the solar roof was a canny decision by Toyota. It may be a ridiculous contraption from an engineering standpoint, but it plays on the heartstrings of those seeking to assuage their guilt about carbon fuels vs. solar power.
