Fixcamx
Discussion in 'Prime Main Forum (2017-2022)' started by jfschultz, May 29, 2025.
  1. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Anyone with experience with Fixcamx or similar dashcam that integrates with the rear view mirror housing?
  2. jfschultz
    639
    115
    Germantown, TN
    2020 Prius Prime
    OK, I messed up. My Fitcamx arrived and got the front installed in about 15 minutes. The hardest part was determining where to put the wire bundle. I'll let an expert deal with the rear camera. Any suggestions on high on the main window, low on the main window, or on the window below the spoiler.
    There is one update compared to the YouTube instal/review videos. The micro SD reader now has both USB-A and USB-C connectors.
  3. primeobjective
    primeobjective Junior Member
    Beaverton, OR
    2022 Prius Prime
    I have the FitcamX for my 2022 Prius Prime. I affixed the rear camera to the top of the interior trim around the upper rear window. Running the cable is relatively easy as the rubber trim around the door openings pulls back to permit the cable to be tucked behind it. I ran it along the top of the door openings, although I may go back to see if I can run it under the door sills instead to reduce/eliminate the risk of interference with the side airbags.
    I use 3M double stick tape made to attach things like mailboxes, i.e. wide temperature range and moisture resistant. Even this tape had trouble adhering to the pebble finish on the interior trim plastic in the long term, so I masked off the area that the tape makes contact with, and sanded it with like 220 grit sandpaper to make it smoother.
    The camera works well, but the app is so-so at best. One caveat: The recording will stop when the app is used to access the camera and review/retrieve files. Supposedly you can resume recording by going to the live view screen and verifying that the camera is recording. I just don't access the camera while it is recording (someone else is driving). Downloading videos can be slow, but the uSD card can be removed and inserted into a PC to retrieve the files.
    PrimeDan likes this.
  4. jfschultz
    639
    115
    Germantown, TN
    2020 Prius Prime
    I bought a lightning uSD reader so I can read the card with my iPhone.
    I found it interesting that apparently you can select QuickTime Player from the open with other and the video will play, but then a second try will just bring up audio. So apparently only when there is a fresh start of QuickTime Player.
    HandBreak can also open the .ts file and convert it to a more common format.
