2009 Bad gas mileage
Discussion in 'Gen 2 Prius Technical Discussion' started by PrimalPrius, Jun 14, 2025.
  1. PrimalPrius
    PrimalPrius Junior Member
    America
    I'm getting only 27-33 mpg, even when purposely driving very conservatively.
    I changed plugs, coils are good, air cleaner is new, PCV valve is new, there are no engine codes.
    There are no codes for the hybrid battery, charging system, etc.
    The traction battery status is blue 99%+ of the time and pretty much the only time I ever see it green (and 1 or 2 of the top bars displayed) is when I go down a really long downhill and I'm able to coast down with no-one behind me. When the battery is green, the car says I'm getting at least 46 mpg in the city (for a short time, of course).
    I got a scanner XTOOL D7S (primarily to scan my brakes and turn off the brake dash light, which it did). The scanner sees 14 battery blocks. My dream was to see one or a couple of battery blocks with lower voltage than the others, but no such luck. The voltages for all of the 14 blocks are very close to each other. The scanner lets me log 8 parameters at a time, which included lowest and highest battery block voltage. The average difference from lowest to highest was 0.14V during the run I looked at in a spreadsheet.
    I have experienced the "Triangle of death" at least 3 times in the past. However, the scanner reported no stored codes due to this. I don't know if these are erased when 12V battery is disconnected.
    All I know so far is that I don't have any obvious engine problems, the regen system and the hybrid assist motor clearly function (to at least some degree), the scanner shows current going into the traction battery and coming out of it, the battery does not appear to have any obviously faulty blocks based on the scanner.
    The scanner shows a lot of different parameters, all of which apparently can be logged. Which ones should I be focusing on in this situation?
  2. PrimalPrius
    America
    I should add that I did have a pretty bad intermittent engine vibration. plugs were so new that I didn't suspect them. I rotated through a new coil and that didn't change anything. I took out the injectors and sprayed carb fluid though them while exercising them with a battery with all of them having a spray pattern that looked pretty good. After that I went and bought 1 more plug to rotate through and while doing that, one of the fairly new ngk plugs came apart in my hand. The center electrode is deformed/broken and needs to be turned only a tiny fraction of a turn in order to pull it out and completely separate it from the rest of the plug (termnal nut end). Lesson learned, always save at least 1 old plug to rotate through for troubleshooting, just in case.
    So I think the engine is fixed and not the cause of the mpg issue.
    #2 PrimalPrius, Jun 14, 2025
  3. PrimalPrius
    America
    One other thing, when changing plugs and or coils on a 2009, the ONLY thing that needs to be moved out of the way for access is the relay box held in place with 2 10mm bolts, nothing else. No wipers, no plastic trim, etc. Super easy job.
    I used a magnetic swivel plug socket which made it even easier, but was not necessary.
  4. Tombukt2
    13,059
    2,340
    Yes nothing out in gen2 for plugs that the next models sounds like ya had fake ngk plugs possibly . Brake lights on to be resetting ? Maybe brakes or hub drag? Look at fuel trims .
  5. bisco
    52,021
    how many miles on her? get critical parts from toyota dealers only. chinese counterfeits are everywhere.
  6. PrimalPrius
    America
    I got the set of plugs that included the broken plug from rockauto. Either way, the engine misfire is now gone and there are no engine error codes.
    Car rolls freely when in neutral with brakes not applied, so should not be brake or hub friction.
    Will log the fuel trims. Although, to get only 27-33mpg, it seems like it would have to be spraying quite a bit of extra fuel.
    Car does report good mpg whenever the battery status VERY rarely hits green.
  7. PrimalPrius
    America
    Around 320,000. if does use some oil so rings probably aren't in the best shape (but as I wrote early, car reports fine gas mileage during the VERY rare times the battery status hits green).
  8. dolj
    dolj Senior Member
    8,451
    4,291
    Wellington, New Zealand
    While your battery is healthy in the sense of delta voltages, it is likely suffering from lower capacity than when it was new. There is nothing you can do about that except replace it with all new modules, preferably from the dealer, as nobody sells new modules that are anywhere near the performance or reliability of OEM new NiMH.
    You might be tempted to try experimental alternate battery chemistry if you have the early adopter proclivity, but I would urge caution. Claims made are not verified by properly accepted research methodologies.
    Brian1954 likes this.
  9. Tombukt2
    13,059
    2,340
    Man just changing your battery from another battery from a car that just came in from a tow lot mite be a thing . because my old junkers with like new batteries get 40 without much discussion.but all of em batt's are better than reasonable engines aren't smoking etc they'll roll down a hill like a soap box derby car on track. So . do not know.i changed my 250K injectors for some cleaned balanced things . Just flooded engine black soot at pintle end. Originals back in running fine .
  10. bisco
    52,021
    i wonder if counterfeit plugs can contribute to poor gas mileage?
  11. pasadena_commut
    pasadena_commut Senior Member
    2,677
    795
    Southern California
    Check the 12V. One that is very much on the way out will drop mpg significantly. Maybe not that much though.
    Get Dr. Prius and run the capacity test on the pack.
    Check the air filter (for the motor, not the cabin).
    Check the oil and coolant levels. Probably they are fine, but as long as you are poking around under the hood...
    Clean the throttle body and MAF?
    Hook up Techstream or equivalent and look at the fuel trims?
    Dragging brake? Drive it on the highway for 10 minutes or so and then park it and walk around and feel the wheels near the hub. If one is dragging enough to matter that wheel will be much hotter than the others. If it is glowing red skip the touch part of the test!
  12. JeffAnd
    JeffAnd Junior Member
    39
    Wisconsin
    On the subject of fuel injectors. Only buy OEM injectors from reputable supplier. Never buy them off of Amazon. Cheap injectors don't have their flow rates balanced. This will result in cylinders running rich and others running lean. Basically it's going to make your fuel trims go nuts. If your long term fuel trims exceed 10%, this will cause a check engine light to come on. Ideally long term fuel trims should be around 1 or 2. The lower the number, the less fuel correction is needed. Simple ways to improve fuel economy. Inflate tires to the proper pressure. Select low rolling resistance tires as replacements. Try to adopt a more fluid driving style. Look for opertunities to coast to a stop. Under some driving conditions won't allow this.
  13. pasadena_commut
    2,677
    795
    Southern California
    Easier said than done. Rolling resistance numbers in the US are almost impossible to come by. In Europe there are ratings up on a web site run by the EU. Doesn't help us in America though because they aren't the same tires as are sold here. The General Altimax RT45 set recently put on our 2007 are close enough in fuel efficiency to the Bridgestone Ecopia EP422 set that they replaced that I cannot with certainty see the MPG difference. The old ones were low RR, the new ones are not. If there is a difference it would most clearly show up in low speed driving (<30 MPH) since air resistance increases rapidly above that velocity.
  14. klerk99
    klerk99 New Member
    US
    Where did you buy the plugs from?
  15. Brian1954
    Brian1954 Senior Member
    2,256
    895
    South Central PA, USA
    Read post #6.
  16. widgeamedoo
    widgeamedoo Junior Member
    Melbourne Australia
    How are you measuring the fuel economy?
