2017 Prime about to reach 160K km, what should be checked?
Discussion in 'Prime Main Forum (2017-2022)' started by sylvaing, May 29, 2025.
  1. sylvaing
    sylvaing Senior Member
    1,210
    514
    So my 2017 Prius Prime is 200 km short of 160K km. Any specifics I should have my dealer or mechanic check before I'm full out of warranty?
  2. Mendel Leisk
    41,896
    Here's a spreadsheet summary of the Toyota Canada 4th gen maintenance schedule. IIRC, there was NO paper publication, I had to go through their website to cobble this one. Both engine and inverter coolant is to be changed.
  3. sylvaing
    1,210
    514
    Thanks, these are the maintenance that should be done but what about the inspection of parts that should be done before my warranty ends?
  4. BiomedO1
    4,125
    2,166
    SacTown, Ca
    They're supposed to be inspecting everything at every dealer service; there's a check list. If they are actually doing it or doing it properly is anyone's guess - or are they just checking the boxes?????
  5. Mendel Leisk
    41,896
    2017 might have the exhaust recovery system coolant leakage. Is coolant level in the engine coolant reservoir stable?
  6. BiomedO1
    4,125
    2,166
    SacTown, Ca
    Unfortunately; he won't know that; if the dealership is topping up fluids. That's one of the boxes they have to check.:cry:o_O:(
  7. sylvaing
    1,210
    514
    I haven't gone to the dealer for maintenance. I changed the sparkplugs myself last year and have the oil change at my mechanic. I do check the engine coolant reservoir at every car wash (I wipe the edges of the openned hood) and so far, there has been no leak. I plan on doing the coolant this summer.
    Story time! A few weeks ago, I was following a Gen4 Prius that was letting out lots of white smoke. Since I was close to home, I followed her and mentioned to her that she might have the infamous exhaust heat exchanger issue. She knew about it and luckily for her, she took the extended warranty for her 2019 Prius. Unlucky though is it's in back order and they filled up the coolant reservoir the week before. Looking under the hood, it was already almost empty (just a bit at the bottom)! I told her to use another car and ask the dealer for free coolant until they have a replacement. It's not her problem if the dealer can't get the part.
    BiomedO1 likes this.
  8. sylvaing
    1,210
    514
    Well, there it is, no more warranty for me :cautious: PXL_20250606_032655998.jpg
  9. bisco
    52,385
    who needs a warranty with toyota? :D
  10. sylvaing
    1,210
    514
    Those with a 2016-2019 Prius :p That exhaust heat exchanger is pretty expensive :eek:
