2006 Prius just dies
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TomLink, Jan 20, 2007.
  1. TomLink
    TomLink New Member
    My girlfriend borrowed the 2006 Prius because it is our new, reliable vehicle. She calls from the car ferry and says it won't turn on. They tried jumping, didn't help. She put the fob in the dash and it worked.
    Other info: the fob was working to lock and unlock the doors, so it doesn't appear to be the fob battery.
    Related question: in the energy use display, does the battery indicate how much charge it has? I haven't paid attention to that level, just the flow arrows. She says it looks low.
    Could it be a problem with the "Power" button? Can she get it home using the fob in the car?
    Thanks.
    Tom Link
    Tacoma, WA
  2. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Check under the steering wheel. There is a black button that disables the radio receiver that communicates between the car's "Smart Entry/Start" and the fob (not the AM/FM radio). When this is disabled, the car and the fob will not communicate.
    If, by "fob works to lock and unlock" you mean actually pushing the buttons on the fob, that's not related to the button. Rather, see if the black buttons to lock and the "grabbing the handle" to unlock work. My guess is that they will not.
    If that's the problem, tell your girlfriend that she is by far NOT the first person to accidentally hit that button with her knee.
    Additionally, Welcome to PriusChat!!
    [edited to clarify "radio receiver"]
  3. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    It could also be a "brake mistake", which is quite common to new owners.
    Pressing it either too soon or forgetting entirely will prevent the car from starting.
  4. TonyPSchaefer
    14,816
    2,501
    66
    About the battery states-of-charge (SOC). I know I'm going to get the numbers wrong but I'll still take a shot at it anyway.
    When you see the battery as "full" in the picture, it is really at around 60% charged physically. Likewise, when you see the battery as "empty" in the picture, it is really around 40% charged physically. And you will so very rarely see either "full" or "empty" that you don't need to worry about it.
    You see, the 'secret' behind Toyota's batteries lasting so long is that they are never allowed to fully charge or discharge. Under normal operating conditions, if the battery ever reaches almost 60% SOC, it will intentionally stop charging the battery. Some people report this condition on very long mountain descents when the wheels are charging the battery. By the time they reach the bottom, they hear some really weird sound coming from the car. This is the rarely heard sound of the Prius "dumping" energy.
    So, in short, don't worry about it.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    If the SKS works for the doors then it isn't an issue w/ the SKS disable button under the dash. If they also don't work then likely that button was accidently hit and just needs to be reset.
    If the SKS works for the doors for sure and NOT for the power-up for sure then other possibilities have to be looked at.
    1)Could be an issue w/ the cabin oscillator...may be disconnected, shorted, or just plain broken.
    2)Could be interference...is there anything in the purse/pocket, whatever that could interfere w/ the signal from the fob?
    3)Possibly a problem w/ the SKS ECU, though that seems a bit less likely since the doors work...you'd think the whole thing would go.
    If the problem persists after looking into the interference issue, making sure the brake pedal was fully depressed, and that the SKS system wasn't accidently turned off then you'll have to see your dealer...the system is complicated and would need repair there.
  6. richard schumacher
    7,666
    1,047
    United States
    If she doesn't have much experience driving a Prius, sit in the passenger seat and watch her go through the whole cycle a few times: getting in, starting it, driving a little, stopping it, getting out. You may find a problem.
  7. efusco
    19,891
    1,196
    Nixa, MO
    One other thought...sometimes the fob will continue to work with the remote button on the doors for a few operations even when the SKS won't work to start the car...so don't rule out an 'almost dead' battery in the fob.
  8. hjon71
    hjon71 Junior Member
    98
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Jan 20 2007, 06:52 PM) [snapback]378399[/snapback]</div>
    I would like to "second " this opinion. The lock/unlock buttons on the fob are not a function of SKS. And yes those buttons will continue to work if SKS is diabled, and the car will start and run just fine with the fob in the dash. List this under one of those been there done that categories. Also this very issue is adressed in the Owners manual.
  9. TomLink
    TomLink New Member
    Hi again,
    Thanks for all the ideas. It was the button underneath the dash - there are 2, it's the Key one that matters.
    Also, great info on the battery display.
    Thanks, Tom
