Anyone seen New Lithium Battery Modules advertised on Offerup? Not Nexcell
Discussion in 'Gen 3 Prius Main Forum' started by 2GenPrius, Jun 16, 2025.
  1. 2GenPrius
    2GenPrius Member
    188
    34
    22
    Californication
  2. Tombukt2
    13,441
    2,418
    There are several people online hustling these plastic copies of prismatics. I've not seen any one running them !
    2GenPrius likes this.
  3. JC91006
    JC91006 Senior Member
    16,827
    8,600
    Why would anyone want to mess with Lithium batteries? Without a properly engineered battery management system, they can catch fire. Surely that should deter you right? These are very dangerous batteries, why do you think there are warning labels on all the shipments you receive with Lithium batteries in them? If your car wasn't engineered with them, best not to introduce it
    Carall, Brian1954 and xw20_driver like this.
  4. xw20_driver
    xw20_driver Member
    103
    53
    PNW
    OfferUp, yea that's the trusted platform where I would look for buying a major HV battery unit for a Prius and trust every word written by the seller. A new factory OEM battery isn't that far off in price than these sus battery packs.
  5. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Jacks customers all say the ecu is the bms and does the job well. We all know what the real answer is now.
  6. ChapmanF
    18,551
    Right, and when Toyota builds a car with Lithium, they put in an ECU with as many channels as the battery has cells, and a volt-sense harness with that many wires. The ECU and harness that come with NiMH are not that, because it would be overkill for NiMH.
  7. ASRDogman
    ASRDogman Senior Member
    7,824
    3,985
    MMM, the car is not engineered for aftermarket parts, best not to use them......
  8. JC91006
    16,827
    8,600
    That's correct. Many aftermarket parts are inferior to OEM. They are built with a lower quality standard and offered at a lower price.
  9. ASRDogman
    7,824
    3,985
    That is not always true. If you get it off ebay, amazon, or at rockauto, it's risky.
    The point I was making, you don't always have to go with oem. Most of the time I buy oem because
    the cost difference is minor, and not worth buying aftermarket.
    I would NEVER buy other coolant or trans fluid aftermarket, but my Prius.
