Help!!! Cranks briefly but won’t start
Discussion in 'Gen 3 Prius Main Forum' started by Bill Frederick, Jun 11, 2025.
  1. Brian1954
    Brian1954 Senior Member
    2,166
    843
    South Central PA, USA
    You should create a new thread for the problem with your car and not hijack this thread.
  2. Brian1954
    2,166
    843
    The answer to your question about the hybrid battery was in post #10.
  3. bisco
    51,851
    Try leaving it disconnected from the car for a few days.
    If it holds voltage, you have a short somewhere, draining the battery while the car is off
  4. Bill Frederick
    Bill Frederick New Member
    Illinois
    So I have an update. I purchased a max pro grid charger. The charger was designed specifically for a GEN three Prius. I installed the wiring harness and tested to see if I installed it properly and everything looked good. I charged it for about 15 hours. Now the car won’t even crank at all. I have kept my 12 V battery charged as well. Any ideas? Is it possible that I missed something?
  5. ASRDogman
    ASRDogman Senior Member
    7,549
    3,898
    Try disconnecting the wiring harness, and install things back to how they were without it.
    The first harness I had from the Prolong kit was defective.
  6. Bill Frederick
    Illinois
    I have uninstalled the wiring harness and there was no change. Still no crank at all now. I’m in the process of checking fuses but everything seems normal so far.
  7. Bill Frederick
    Illinois
  8. Bill Frederick
    Illinois
  9. ASRDogman
    7,549
    3,898
  10. Brian1954
    2,166
    843
    Use a meter and measure the voltage of the hybrid battery. Come back and post what the meter showed you.
  11. Bill Frederick
    Illinois
    So it was as simple as the safety switch. I did not click it over after reinstalling it. I discovered my error right before I read your post. Car started right up and seems to be running ok right now. I’ll continue to monitor everything. Thanks for all your help. I’m ok with doing something stupid so long as it’s running
    Mendel Leisk, Brian1954 and ASRDogman like this.
  12. ASRDogman
    7,549
    3,898
    Always go with the simplist things first.
    See post #19...
    But I am glad it's running! Great feeling isn't it?
  13. Bill Frederick
    Illinois
    Indeed it is!!! I haven’t needed the vehicle so it’s nice to get it out of my garage :) thanks again
    ASRDogman likes this.
