What does "remanufactured" mean?
Discussion in 'Gen 5 Prius Main Forum' started by Winston Smith, Jun 17, 2025.
  1. Winston Smith
    Winston Smith Active Member
    390
    268
    OH
    2024 Prius
    LE AWD-e
    I'm looking for another set of wheels for an LE. Some of the wheels are described as "remanufactured". For a wheel, is this just a euphemism for used? Or is there some implication that it has been damaged and repaired?
  2. notspam3
    notspam3 Member
    88
    45
    Toronto
    2024 Prius Prime
    XSE Premium
    It means refurbished used items
    Steel wheels typically get sandblasted and repainted
    Winston Smith likes this.
  3. Mendel Leisk
    41,850
    I got a remanufactured rim from Rock Auto. It was a used rim, looks to be straight, cleaned up and repainted.
    If it was say a remanufactured brake caliper, that should be inspected, clean, new gaskets, a little more involved.
  4. Winston Smith
    390
    268
    OH
    2024 Prius
    LE AWD-e
    What does it mean for an OEM aluminum wheel?
  5. Paul Gregory
    Paul Gregory Senior Member
    2,223
    591
    Alberta
    2024 Prius Prime
    XSE
    I believe there's an industry for repairing wrecked rims:
  6. Gokhan
    Gokhan Senior Member
    6,493
    2,596
    Paramount CA
    Never buy used wheels per Toyota owner’s manuals.
  7. notspam3
    notspam3 Member
    88
    45
    Toronto
    2024 Prius Prime
    XSE Premium
    Aluminum wheels can be blasted and turned to make round again and then repainted. I would never buy refurb aluminum alloy wheels. They might look pretty after refurb but you can't see the microstructural cracks which will lead to failure. Bent alloy wheels results in cracked alloy wheels which is why they tend to get re-melted instead of refurbed.
    My motorcycle manual says "do not attempt to repair or use refurbished alloy wheels" which is good advice IMHO.
