What's the newest data analysis and results? --- EGR clean prevents HG gasket or is it inevitable
Discussion in 'Gen 3 Prius Main Forum' started by Eun yushiro, Jun 20, 2025 at 9:06 PM.
  1. Eun yushiro
    Eun yushiro Junior Member
    Van Nuys, CA
    2014 Prius Plug-in
    Our 3g's have hit high mileages now and even more sample sets of data...
    Does the EGR + intake manifold clean actually help prevent Head Gasket Failure - or are those that saying it's Inevitable the HG fail --> Correct?
    Wondering what the conclusion is in your opinions given that we've had much more miles put on our cars
    Why is this important. Can help others know if they should just preventatively change the head gasket now, as well as do the EGR clean, or really just do the EGR clean and be done with it
    My prius is at 128k miles
    Just got the EGR valve and cooler out -- Took me 1 month with the car sitting in the garage. I'm learning how to work on cars (i'm a hospital therapist by trade) -- none of this is easy and takes me 10x longer to do
    Please do share the data. I'm wondering if I should just learn how to change the head gasket now to Fel Pro but it seems way over my head and I don't have the time to just sit hours in the garage. Have a beautiful young baby daughter I spend all my time with and would prefer it that way
    51,034
    unfortunately, there is no data. data requires controlled testing and record keeping, of which we have none.
    what we do have is a lot of experiences reported, good and bad. we do know that not every head gasket blows, if you put some mileage/time on the answer.
    toyota says it is badly designed water pump speed software, for which they offer an update (in europe only?)
    many guesses here include egr and related assemblies, defective head gaskets, 10k oil changes, infrequent coolant changes or even ph testing, poorly designed pistons and rings, and etc.
    how to make sense of all that?
  3. Mendel Leisk
    40,487
    A lot of the naysayers give examples, owners that clean their EGR when the odometer's into six digits, and maybe even exhibiting head gasket failure symtoms, such as cold-start shakes, losing coolant. The concept of "interference engines" comes to mind, basically something advantagious is applied to an engine, with the caveat that something else is implemented, to allow that application to work safely.
    With 3rd gen Prius, better mpg (a tenth or two of a mpg) was achieved, by running it leaner, and to keep the engine from overheating the EGR system was added. If Toyota had bothered to run a few test cars for 200k miles, we likely wouldn't be where we are.
    Same could be said for the low-friction piston rings. Anyway:
    ^ A lot of times the naysayers will say "I cleaned the EGR, and head gasket still blew". When asked at what miles, it's typically around, well, your miles. Bottom line, just from reports here, my take is it needs every 50k miles, or less. Any more than that, the EGR is compromised, has reduced flow, unbalanced flow and/or overheated flow. Likely all three.
    Belated cleaning is still good to do, but definitely don't get complacent. Our third gen YouTube guru @NutzAboutBolts cleaned his EGR and intake manifold around 120k, and is now having head gasket failure, around 180~190.
    See the top two links in my signature*, also see this workflow summary (just for the EGR side of it, not the intake manifold).
    * on a phone turn it landscape to see signatures
    Not sure if it's mentioned in any of the above links, but exclusively for the EGR cooler, I'd recommend a lye solution soak, for fast/thorough cleaning. It's stainless steel, impervious to lye, and really needs something strong, due to the internal radiator labyrinth. For everything else brake cleaner, brushes and rags will do. You definitely DO NOT want to or need to use lye on anything else. It will react with aluminum, non stainless steel.
