AC Eco Mode
Discussion in 'Gen 5 Prius Main Forum' started by daisy555, Jun 20, 2025.
  1. daisy555
    daisy555 Senior Member
    1,700
    697
    CT
    I’m finding that I can have the AC off but still get cool air coming thru the vents on a warm day. Other times I try to switch the outside air circulation switch on or off but the switch light doesn’t come on or shut off. I’ve also been told there is a way to turn the AC to eco mode within the info screen but I do not see this as an option.
    I’ve reviewed the AC section in the manual. Any ideas? I see others having this issue as well. Thanks
  2. thetoys
    thetoys Member
    28
    Toronto, ON
    2024 Prius Prime
    XSE Premium
    I find the easiest and quickest way is to press the AUTO HVAC and toggle the Drive Mode Console Switch (Near Shifter) to ECO.
    RandyPete, sclevine and PrimeDan like this.
  3. sclevine
    sclevine Active Member
    149
    149
    NE Florida USA
    2024 Prius
    Woah, this works! Been looking for this answer for a long time! I was able to change the custom mode to have eco drivetrain and non eco AC, and now I can switch the drive mode to Eco if I want the eco AC and Custom if I don't want the eco AC.
    Thanks!
  4. daisy555
    1,700
    697
    CT
    Can the AC be set to ECO without the drivetrain being set to ECO? I thought ECO mode was best for city driving.
    I’ve seen people reporting getting better mpg when using normal mode for mixed highway driving. My only interest in AC being in ECO mode is for fuel economy.
  5. Gorgonzola
    Gorgonzola New Member
    28
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    Yes, this can be accomplished through the “custom” drive mode
  6. Rugged_Rowan
    Rugged_Rowan New Member
    Southeast
    2025 Prius
    you can also manually control the ac to "eco mode" on the vehicle settings on the radio screen. That's where I changed mine and everytime now when I turn ac on it is on eco mode while my driving mode can change , eco mode on ac would remain
    Gorgonzola likes this.
