Getting conflicting answers on google about how much oil is needed to do an oil change.
Discussion in 'Gen 3 Prius Technical Discussion' started by h1ph0panonymous, Jun 20, 2025.
  1. h1ph0panonymous
    258
    36
    2014 Prius 75k Miles
    I got search results ranging from 4.4, 5 and 6 quarts needed for an oil change. Which one exactly?
    1. 4.4 quarts
    2. 5 quarts
    3. 6 quarts
    Also which 0W-20 full synthetic do I need, any preferences, cheap or good ones would help with exact names and parts numbers from said store or provider of said oil and why you prefer it. As well as the oil filter, which kind exactly and which do you guys prefer and why?
    Seeing what I’m looking to pay for all of it once I get some good input on which kind is best or preferred.
  2. Tombukt2
    12,908
    2,318
    Wal Mart silver or gold oil it's eye level on shelf 18.99 here here's a good idea drain oil out remove filter cart. You bought 5qt bottle oil put in drain plug add 4 qts oil start car let idle a few seconds turn off wait a few seconds like 30 pull stick out wipe return and pull again add oil till hatch marks are covered it'll be 4 4 to 4.6 purdy much
    h1ph0panonymous likes this.
  3. h1ph0panonymous
    258
    36
    The dealership I get oil changes at for the past two years has been charging me for 6 quarts @ $10/each, why would they be using 6 quarts? Are they using a quart to flush out the old oil?
  4. Tombukt2
    12,908
    2,318
    Maybe I do it sometimes especially with the new to me vehicle might get done twice especially on a 3
  5. Tombukt2
    12,908
    2,318
    But wen I used to pump gas . I used to kill it hustle 300 a day in the 80s hi value gasoline Corp look em up
  6. Tombukt2
    12,908
    2,318
    Wen I worked at dealer I could change oil daily seriously .. I mean in my car ...nuts .
  7. Tombukt2
    12,908
    2,318
    Funny story my first car a Corolla w 2tc hemi engine I drove almost 400K never changed oil . It'd get low id add every few . months id spin off the ph8a and screw on new one cat never died never it's still parked in a local junkyard the body fell apart .
  8. Brian1954
    Brian1954 Senior Member
    2,166
    843
    South Central PA, USA
    When you change the oil and filter, you need 4.4 quarts of oil to refill it.
  9. Hayslayer
    Hayslayer Active Member
    390
    219
    I don't want to seem a jerk, but you may be better off continuing to use the dealer for your oil changes. You're going to end up with a drain plug falling out or filter falling off.
  10. smeezy
    smeezy New Member
    Utah
    0-20 full synthetic 4.4 quarts
  11. Leadfoot J. McCoalroller
    8,072
    7,553
    Pennsylvania
    2018 Prius c
    Any 0w20 that bears the API "SN" rating or better (which is almost all of them) will be good enough. The costco and walmart house brands are fine. No need to fool around with special varieties advertised for "high mileage" etc.
    I tend to find what we need for about $23 per 5qt jug, just for reference.
    Take your time and do it right.
    Good luck!
    h1ph0panonymous and Brian1954 like this.
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    You must have researched right into the guy who posted that he filled his oil to 6 quarts and only drained the oil by removing the filter the last 4 oil changes!!!
  13. Mendel Leisk
    41,346
    Did your search include the Owner’s Manual?
    When I'm changing oil and filter, with just the front raised, quite high, and let it drip well, I put in 4.2 liters, carefully measured with a graduated pitcher. Subsequent check, after a few days driving, I'll see oil level maybe 1/8" below the top mark.
    When checking the dipstick, after pulling and wiping it off the first time, wait about 5 minutes, before reinserting for the check. The wait gives oil drawn up the guide tube time to drain down, so you get a clearer oil level reading.
    More info in the oil change link in my signature. (on a phone turn it landscape to see signatures)
    #13 Mendel Leisk, Jun 21, 2025
  14. h1ph0panonymous
    258
    36
    But they charge me for 6 quarts of oil LOL
  15. h1ph0panonymous
    258
    36
    Thanks for that info and procedure, I'm still confused why the dealership has been charging me for 6 quarts. I’ll have to call and ask.
  16. h1ph0panonymous
    258
    36
    Maybe, but also looking at my last oil change from the dealership it says they used 6 quarts, Wth.
  17. rjparker
    10,102
    6,266
    Basically when they see an owners manual which has no crease marks on the binding they say "don't go by the book today boys! Drinks are on me after work!"
    Seriously dealers I use don't charge by quarts of oil. Around here they charge $79 for an oil change with filter. Plus tax and ridiculous shop fees. Sometimes they offer a buy one get one free which is somewhat worth it if you don't like crawling around under a jacked up car.
  18. h1ph0panonymous
    258
    36
    Sad for me then, I even use the works coupon they give me ($79.99) with all fluid checks and fills along with inspection and tire rotate which they forgot to rotate once because I have my tires marked. The total last time with a coupon came out to $120ish…because “your Toyota oil is expensive” @ $10/quart x “6”.
  19. rjparker
    10,102
    6,266
    My dealers do all the fluids, filter and an "inspection" for $79. Taxes and fees add $20. Tire rotations - free where I bought them but would be $20 extra at the dealer.
    Same pricing without the quarts bs. The service advisors work on commission - so there is little left to figure out.
    The fluids never need topping off, the multipoint inspections are a joke (just trying to sell wipers, alignments, brakes and air filters).
    Dealer "maintenance" won't prevent head gaskets, brake boosters or hybrid batteries. Find a half price oil change option and do it every 5k miles. Change the engine coolant every 50k - one of the easiest jobs on the car. Same money - better chance at longer mileage.
    #19 rjparker, Jun 22, 2025
  20. Noahdoge
    Noahdoge Active Member
    202
    144
    Mississippi
    I’d definitely talk to the service manager, don’t bother with the advisor. They owe you for all the times you’ve paid for an extra quart of oil. Before I bought my house I would take a 5 qt jug and my oil filter to my local mechanic and he would charge $30 for labor. I just got tired of the $120 oil change and wasting an entire Saturday for something so simple.
