Possible to buy a Prime with the Solar Charging Roof?
Discussion in 'Gen 5 Prius Main Forum' started by maiki, Jun 20, 2025 at 2:59 PM.
  1. Hammersmith
    Hammersmith Senior Member
    1,966
    1,971
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    edit - I thought I found 8 within 500 miles, but I see now there's something wrong with the search function. It's returning results for cars it shouldn't be. I'm going to do a little playing around to see if I can trick it into giving correct results.
    edit2: Okay, there's a weird bug in the Search Inventory software that shows you the wrong results if you select both Adv Tech and Solar Roof. So just choose Solar Roof. It looks like the vast majority of cars that have the Solar Roof option also are XSE+ with the Adv Tech Package.
    There's only 5 within 250 miles of you that are not sale pending, but if you expand to 500 miles that number becomes 33.
    Toyota Inventory | New Toyota Inventory Search
    #21 Hammersmith, Jun 20, 2025 at 8:31 PM
    RandyPete likes this.
  2. RX808
    RX808 New Member
    2025 Prius Plug-in
    XSE Premium
  3. thetoys
    thetoys Junior Member
    31
    Toronto, ON
    2024 Prius Prime
    XSE Premium
    I’m assuming the Solar Roof also trickle charges or maintain the small 12v Battery if the car sits idle for days or weeks on end without plugging in.
    If it prevents a dead 12v battery then it might be a good option for some.
  4. Paul Gregory
    Paul Gregory Senior Member
    1,386
    360
    Alberta
    2024 Prius Prime
    XSE
    I wouldn't assume that. I think it's for charging the hybrid battery.
    But it would be much more useful for that purpose.
