Current State of the Art in Battery Balancers?
Discussion in 'Gen 3 Prius Main Forum' started by jimolson, Jun 21, 2025.
  1. jimolson
    jimolson Member
    155
    58
    Indianapolis, USA
    This question is prodded by having recently paid a well-known Indiana Prius recycling business (ABY) to replace the traction battery in my daughter's 2010 with a new Toyota one. The process went well and quick and I was on the road headed back to Indianapolis within an hour of arriving.
    While he worked on the car Steve talked (as he is known to do) mentioning that Toyota in the past year has dramatically raised the price of new Gen 2 and Gen 3 battery packs. If what Steve cited is correct, the price increase represents predatory behavior by T whose purpose is clear: to flush remaining old Prii off the roads. No way that battery pack needs to cost that much. PrimeEarth's tooling was long ago paid for.
    I have watched with a bit of amusement the growth of the hybrid battery refurbishment industry over the past few years. 13 years ago I tried a couple of refurb'ed batteries in Prii and the experience was underwhelming.
    In those days refurb shops had no equipment to "treadmill" the cells and determine which ones had remaining life. The term internal cell resistance was never mentioned in ads or reviews, probably because there was little equipment to measure that parameter and the folks doing the refurb'ing generally have little technical training.
    Today it appears the refurb'ers use repurposed charging hardware designed for radio-controlled airplanes and cars. Technically trained people have even networked these hobbyist chargers and can today operate them from laptops and provide charge/discharge curves for cells.
    But I've noticed that the home-brew treadmill apparatus sold on the internet assumes that the Prius battery pack has been disassembled down to its individual cells. While the battery stack is disassembled and its cells exercised, their dimensional thickness changes and reassembling the battery stack into its compression frame can be difficult.
    As a practicing electrical engineer who designs and builds circuit boards for a living it occurs to me that it should be possible to "treadmill" cells and sort them by discharge capacity while they are still bolted together in a stack. In other words, it should be possible to acquire detailed data about each cell with them still compressed in Toyota's factory frame and bus-barred together.
    Doing this could be riskier from a safety standpoint because the cell stack's normal voltage is greater than 200VDC, but lots of consumer electronic hardware contains unsafe voltages from which the user is adequately protected. The known protection methods are line operated power supplies designed with double isolation and enclosing the entire sub-assembly in a well-designed polymeric housing.
    Is what I'm I describing (a line-operated battery charge/discharge device tolerant of high common mode voltage) something that has already been designed?
    #1 jimolson, Jun 21, 2025
  2. JC91006
    JC91006 Senior Member
    16,767
    8,565
    Yes, you can get the entire pack refurbished, charge and discharged quite easily. Hybrid Automotive was one of the early adopters of this, since then there may be better and more reliable equipment than what they are putting out. It's not necessarily accurately measuring the remaining capacities of any of the modules, but to recondition them by discharging the modules to a really low voltage then recharging them back up....doing this for a few cycles will recondition them and bring the modules back to a healthy balance again.
    Brian1954 likes this.
  3. Tombukt2
    12,931
    2,322
    Oh you're not going to get down to the cells unless you're going to cut hermetically sealed prismatic modules be interesting trying to plastic weld them back together .
  4. Madmommymelinda
    Madmommymelinda Junior Member
    Lexington, KY
    2014 Prius Plug-in
    Im an electric engineer as well. I also happen to work for a Toyota plant and was hybrid system trained many moons ago where they attempted to scare us away from ever attempting to do exactly what you are describing. Well, im currently looking to do exactly what you are describing as I dont scare easily. I've built a battery charger/discharger (because im too cheap to buy one). I've actually not had the time to test its function but looking forward to it. I said all of this to 2nd what JC said. Regarding the acquisition of cell data from the pack without breaking it down, I don't know how this would be possible without 1st installing electronics and hardware within the pack itself. I dare say that if it were already capable, the dealerships would be using this technology. If this is something you were to design, and build, I bet you would make a killing as every handy hybrid owner would know in real time, the condition of their battery. Let me know if im way off base.
  5. JC91006
    16,767
    8,565
    Techstream actually has a bunch of information you can pull while the battery is in the car. It just doesn't break it down to each individual module. It does it in blocks. But there are apps available that can generally give you a decent idea of the condition of the battery block. Anything professionally built is not worth it for the home user, the PLC equipment will cost thousands to monitor the battery. Just better off buying a new battery and call it a day.
    The best testing tool to use is probably the car itself. As it throws 100a at the battery. If there is a problem module (when the battery SOC is low), it would fail quite quickly with 100a thrown at it.
    Brian1954 and Madmommymelinda like this.
  6. rjparker
    10,119
    6,280
    I think the first questionable assumption is a recycling business installed a new battery. Assuming a reconditioning outfit restores bad modules is not true either, bad modules are replaced with better used stock. Life of the rebuilt assemblies is still short unless they actually installed brand new oem nimh modules.
    The idea of individual "reconditioning" old modules in place seems difficult but not impossible if you are willing to install isolation devices between modules and individually switch each module into and out of the circuit for a "reconditioning" attempt by automated equipment carried in the trunk.
    I think it would be easier to install a set of the cheaper cylindrical nimh cells and have the same net result, eg a lower cost - albeit temporary, solution than a dealer offers.
    Of course there was a company doing just that with cylindrical nimh but reliability issues and short lifespans sullied their reputation.
    johnHRP likes this.
  7. JC91006
    16,767
    8,565
    cylindrical solutions that have been pushed here on Priuschat have only lasted about 3 years, they are not very good. And the guy pushing those batteries no longer come to the forum anymore, claiming he has so much business he can't keep up with us little guys. Bunch of BS
    The recycling business is probably AutoBeYours, they seem to be good at what they do, been in the business long enough to do a decent job with the Prius recycling business
    johnHRP likes this.
  8. Tombukt2
    12,931
    2,322
    I cannot believe there's so much BS with batteries going thru similar w volt ELR crap. Bunch of nonsense can do companies out they're cannot be hard to fill three rectangle shaped boxes w modules and two cooling passages you'd think . He he . Oh well few more years.
  9. jimolson
    jimolson Member
    155
    58
    Indianapolis, USA
    rjparker, the new battery installed in daughter's car was done by a shop in Southern Indiana that sprang up around 2007 when the availability of Prius parts (mostly post-collision body panels, etc.) was poor. Steve developed a relationship with Midwest insurance companies and bid on large numbers of totaled Priuses. He built the gig into a going enterprise and cultivated good relationships with Toyota dealerships in the Louisville area for Toyota-only parts. He had an area at his business where he sold rebuilt Priuses.
    I've always used Steve because he's impeccably honest and his discount with local dealership parts departments must be huge. His traction batteries are indeed new PrimeEarth ones because I watch him remove them from their shipping container. The batteries carry factory stickers denoting them as new PrimeEarth product.
    Enough promotion of ABY and Steve. My daily driver is one of his rebuilt vehicles from 2008, now with 300k miles on it.
    For those of you who read and remarked on my notion of a battery treadmill device that can do its job with the battery stack still assembled, I'm not proposing that it be done in the vehicle. The battery stack would need to be removed from the vehicle and placed on a workbench, but still clamped with its compression bars and its cells still bus-bar'ed together.
    And I'm not proposing that someone spend significant time with the battery pack without wearing appropriate gloves and safety glasses.
    Though I have never done it, I believe that the end terminals on the 7.2V NiMH cells can be exposed without removing the cell from the stack. In other words, you have electrical access to the terminals you need to "treadmill" these cells and perform an impedance test on them.
    The means by which the proposed tester grasps the the cell's terminals is up for discussion, but the grasping method need not be "150 amp reliable" because it's unnecessary to treadmill a cell at high current to fully characterize it. I think 10 amp loads and 10 amp charging is sufficient to exercise a cell and predict its remaining life.
    Pomona/Fluke makes a huge spring-loaded test clip ("maxigrabber") that can do 10 amps. There isn't enough exposed metal on a Maxigrabber to accidentally short circuit adjacent cells.
    An affordable treadmill tool might need to be one that accommodates just one cell at a time. Rather than get data into and out of the device using traditional computer cords (RS-232 or USB) I'd propose that the device be Bluetooth or have a short fiber optic patch cable to an adjacent laptop in the interest of safety.
    There is no reason that bus bars between adjacent cells (or the other electronic hardware present in the metallic enclosure around the battery stack) will affect--or be affected by-- any sub-10 volt testing of a single cell.
    Yes, there is potentially 200VDC of common mode voltage on the battery stack but it's not ground-referenced. I believe the stack is isolated from chassis ground and this isolation is tested by Toyota's battery management system with a ground fault interrupter circuit.
  10. PriusTech
    PriusTech Active Member
    247
    105
    Reno
    There are several high end professional chargers for refurbishing and maintaining hybrid batteries but they are in the $5000 to $10,000 range and up. If you buy a refurbished battery it probably should be from someone that has this equipment.
    That said there are good alternatives for the DIYer. I think grid charging is the way to go, charging/ discharging/ charging the whole pack at once. The only reason for cell pack disassembly is to replace bad cells. There are 3 DIY level grid chargers/ dischargers (probably more?) Prolong, Maxx Volts, and Venice Hybrid Tech. All under $1000. They are sold with a harness that you install on the battery and then you just have to plug in the charger/ discharger. It's not a simple process and it is time consuming, like 2 to 3 days, But it can significantly gain more life and performance for an older hybrid battery. It's something you might do once or twice a year. And it also requires a smart phone app like Priusapp, or Torque app, which both work with a Bluetooth OBD2 module. You have to be able monitor battery condition for bad cells, or to see if the assembly is getting weak and to confirm charging quality and improvement.
    I've also looked at the single cell charging/ discharging reconditioning method. I haven't found a good charger for this, they are all Chinese and unreliable. And you need to be able to charge/ discharge at least 8 cells at once, so 8 separate charging circuits. There's a YouTube vid of a tech charging only 4 cells at once and it took 16 days. There's probably a good multi channel charger out there, but just the method itself of having to completely disassemble and charge individual cells is more labor, when you can get the exact same result with grid charging.
    Prius hybrid batteries do degrade over time. It's only a fast charge discharge system, it does not trickle charge, it cannot rebalance once balance is lost. The system does not charge discharge balance the battery like a grid trickle charger does. You do have to locate and replace bad cells once you get the red triangle P0A80, before you grid charge. Also the cells in the center run hotter than the ones on the ends, so you can swap them inside to outside to help with the balance.
    I have a 2nd gen Prius and a Lexus CT200H, which is a 3rd gen Prius drive train. 5 years ago the original battery in the 2nd gen went bad and I put a new D cell conversion, but it only lasted 5 years. Now they both have the red triangle and I'm going to refurbish the hybrid batteries in both of them, and I should do a post about it. I've seen the Prius app show a battery going from 50% life to 90% with grid charging, so I think this is a viable option.
    #10 PriusTech, Jun 27, 2025
    gdanner and PrimeDan like this.
  11. PriusTech
    247
    105
    Reno
    This is the charger most often used in YouTube videos when the hybrid battery modules are being charged separately. I think the original manufacture is going out of business. EV-PEAK.COM. All their products are listed as unavailable and the last correspondence on their page is from 2022. It looks like some other Chinese companies have copied and its still being produced. Its been made in 2 different colors red and blue. It's had 3 different brand names, Bgaud, Ampgo, and Ecube, all calling it the CQ3. It was sold by about 10 hobby shops, that's down to 1. It's on Amazon with really bad reviews, 10% 1 star. It has a warning (often returned item). It's on Ebay but only ships from China. Around $230. If this wasn't unreliable it would be really good because its a 4 channel charger / discharger in one and its fully automated. If you ran 2 of these you could fully recondition a battery in 3 to 5 days
    #11 PriusTech, Jun 28, 2025
  12. PriusTech
    247
    105
    Reno
    This is a single channel hobby charger / discharger from a reliable brand Tenergy. This would be used as a individual module charger / decharger, fully automated. $40 each and you would want 8 of them to complete the job in 3 to 5 days. So $320. This is probably the way to go if you want to charge individual modules. 14 of them would be $560, less than the grid chargers. I'm sure there's other reliable brands in this configuration but Tenergy is the only one I have experience with.
    #12 PriusTech, Jun 28, 2025
  13. PriusTech
    247
    105
    Reno
    Just for fun here's some high end professional charger / dischargers. From $5000 to est $15,000. 30 and 40 channel chargers would charge individually in one go.
    #13 PriusTech, Jun 28, 2025
  14. PriusTech
    247
    105
    Reno
    These are the DIY grid chargers from VeniceHybridTech.com. An entry level charger, a higher power charger, and a discharger that uses a Home Depot Halogen worklight for the load. $200 to $600
  15. PriusTech
    247
    105
    Reno
    These are the chargers / dischargers from Maxx-Volts.com. A grid charger with a programmable shutoff, one without the shutoff, and a discharger that uses the same connector as the chargers. $300 to around $750
    #15 PriusTech, Jun 28, 2025
  16. PriusTech
    247
    105
    Reno
    These are the DIY chargers / dischargers from HybridAutomotive.com (Prolong). They have a Grid charger, a programmable discharger, and a entry level discharger that uses light bulbs for the load. Available separately or as kits. $300 to around $750
    #16 PriusTech, Jun 28, 2025
  17. PriusTech
    247
    105
    Reno
    The Venice products are the most affordable but maybe with a few less automatic features.
    Maxx Volt and Prolong are neck and neck on features and price. With the Maxx Volt charger being more programmable and the Prolong discharger having the programmable advantage. So maybe combine the 2 with an adapter harness.
    Additional info, comments, corrections of bad info are welcome
    #17 PriusTech, Jun 28, 2025
  18. PriusTech
    247
    105
    Reno
    More info.
    Besides the PriusApp, and the Torque App, there's also the Prius Hybrid Assistant app, It works just fine with the Prolong OBD2 bluetooth module that's recommended for the PriusApp.
    There's also another way to find bad modules that need replacement before grid charging. Use the Viking 12V digital battery and system tester from Harbor Freight, it gives a resistance reading and will test individual modules even though they are not 12V. It rates batteries, good, charge, and bad.
    There's also a Insulation test with a mega ohm meter which can identify individual bad modules
    Also things have changed for Toyota Techstream, the recommended OBD2 module is NLA. Now according to GTAAUTO.com and their Toyota Techstream full installation guide the VXDIAG VCX NANO is the best OBD2 interface.
    #18 PriusTech, Jul 4, 2025
  19. Brian1954
    Brian1954 Senior Member
    2,180
    854
    South Central PA, USA
    Did you mean the Panlong OBD2 Bluetooth module?
  20. PriusTech
    247
    105
    Reno
    Yes, sorry about that
