Passenger wiper arm issue - Are both splined shafts driven by the motor?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sneeze7598, Jun 21, 2025.
  1. Sneeze7598
    Sneeze7598 New Member
    PNW
    Having some issues with the passenger wiper getting in the wrong spot and crossed with the driver wiper. I pulled of the passenger wiper and noticed that the center splined shaft rotates with the motor, but the far right side (passenger most side) does not rotate. Is this correct?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    Yes, that's correct. The one (center) pivot "drives" the right wiper arm, while the second (far right) pivot just guides it. That pivot should just rotate freely.
    I would make sure that the splines are clean. Set the wipers to the "parked" position for assembly. Tighten the pivot to arm nuts to 15 ft-lb.
  3. Tombukt2
    13,306
    2,398
    You can put a dad of goop on that splined stud get wiper right push down on spring of wiper and tighten nut . Let it stand 30 minutes and wet glass and wipe . Good now
  4. douglasjre
    douglasjre Senior Member
    2,199
    734
    Null, NL
    Remove cover
  5. Sneeze7598
    PNW
    I put on a new wiper arm from a junkyard because the splines on my arm were worn smooth. Been working fine since. Thanks for the help everyone.
    douglasjre likes this.
