Toyota Digital Rear View Mirror 87840-0W360 (no homelink)
Discussion in 'Gen 5 Prius Accessories and Modifications' started by otatrant, Jun 18, 2025.
  1. otatrant
    otatrant Active Member
    240
    156
    San Francisco
    2023 Prius Prime
    XSE Premium
    I have been looking into the Toyota digital rear view mirrors for a while pretty intensely when I got my car and than again recently. Finally made sense of some of the models listed as compatible with the 5th gen prius. Pretty sure that model 87840-0W360 is the model number for the digital rear view mirror without homelink buttons on it.
    Here are some picks I found on a Taiwanese web site.
    I found a pretty decent price from a Thai web site Yoshi Parts $630 with shipping for 87840-0W360. Never ordered from them before but they look like they have some happy customers according to google.
    The $630 does not include the rear mirror assembly and camera. Parts still needed to do the install would be the rear camera assembly 86790-47190 which includes another backup camera and the housing with the mounting points for both cameras. Than I would still need the digital rear view mirror camera 867C0-30040.
    That would get me most of the essential pieces without the necessary wires or harness.
    In summary to me this looks like the best way to add a Toyota OEM digital mirror since it is quite a bit cheaper than previous posts I have seen with parts and prices. I am not in a rush to take this project on but think I will eventually. Currently have a bullet network camera mounted on my roof rack that I think will work well in the meantime to stream a view out the back to an old iPhone once I finish wiring it up.
    Anyone have any experience with purchasing from Yoshi Parts or any feedback on part numbers and my understanding of the components involved?
    apissues likes this.
  2. Hammersmith
    Hammersmith Senior Member
    2,181
    2,185
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    FYI: Same mirror(87840-0W360) is about $400 from Impex Japan. Maybe another $40-60 for shipping.
    apissues and otatrant like this.
  3. fotomoto
    fotomoto Senior Member
    5,632
    3,805
    So. Texas
    Another FYI, DRM's with outside camera mounts NEED a washer.
    If going aftermarket, placing the camera inside and within the rear wipers wipe zone is an ok workaround. Opps, 4/5 gen Prius don't have a wiper either.
  4. otatrant
    240
    156
    San Francisco
    2023 Prius Prime
    XSE Premium
    I don't think this is correct anymore.
    I think the two main pieces (camera assembly and mirror) when upgrading are the rear camera assembly 867A0-47020 which includes both the reverse camera and the digital mirror camera. I ordered one and will be able to confirm shortly if this is correct once I receive my shipment.
    Here is the parts diagram from amayama.com.
    Here is the pricing from impex for 4 rear camera assemblies.
    Still can not understand exactly is different between the two cheaper rear camera assemblies. My best guess is that it is a higher resolution camera for use with panoramic view monitor.
  5. Hammersmith
    2,181
    2,185
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No. The difference is the more expensive one comes with the washer parts and the spot for the second camera.
    86790-47150 - Just the backup camera and mounting plate w/o washer
    86790-47180 - Just the backup camera and mounting plate w/ washer
    867C0-30040- Just the camera for the rear view mirror
    867A0-47020 - 86790-47180 + 867C0-30040
    There's also 86790-47190 which appears to be the backup camera and mounting plate w/o washer but can still accept the rear view mirror camera. I guess that if you want to add a factory digital rear view mirror, but don't want to try and add the panoramic view monitor, that's probably the one you would want.
    #5 Hammersmith, Jun 22, 2025
  6. Hammersmith
    2,181
    2,185
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Take two, for additional clarity and prices:
    Prices: US MSRP - 31%+20% discount - Impex
    86790-47150 - base version - backup camera only ($151.88 - $84.01 - $107.38)
    86790-47190 - backup camera, spot for rear view mirror camera ($237.36 - $131.29 - N/A)
    86790-47180 - backup camera, spot for rear view mirror camera, washer assembly ($149.84 - $82.87 - $151.71)
    867C0-30040- rear view mirror camera ($342.06 - $189.19 - $240.39)
    867A0-47020 - 86790-47180 + 867C0-30040 ($347.95 - $192.46 - $352.62)
    Looks like this is one of the cases where it's cheaper to buy from Toyota USA(during a sale) than import from Japan.
  7. KMO
    KMO Senior Member
    1,882
    641
    Finland
    2023 Prius Prime
    Not sure I'm buying @Hammersmith 's taxonomy.
    From what I've seen previously, there is a low-res crummy version of the reversing camera, so it looks to me like:
    47150: crummy low-res one (SD video?)
    47180: decent one (digital, wide-angle)
    47190: decent one with fitting point for digital rear view mirror
    Edit - trying again after staring and comparing catalogues more.
    47150 - crummy low-res (SD video?) reversing camera, no digital mirror fitting
    47190 - crummy low-res reversing camera, digital mirror fitting
    47180 - decent (digital, wide-angle) reversing camera, digital mirror fitting
    47190 might not be a real production part. 47180 is the only part in Europe, where you always get the good reversing camera.
    What's the deal with the rear view mirror in the USA?
    Am I right in thinking that the base models have the low-res reversing camera, and the decent one comes with the panoramic view package in the Limited? But the rear view mirror isn't dependent on the panoramic view?
    Do you get the decent reversing camera with the rear-view mirror? If so, maybe that's an inventory simplification - they decided to forget about the 47190 bad-reversing + digital mirror option.
    #7 KMO, Jun 22, 2025
  8. otatrant
    240
    156
    San Francisco
    2023 Prius Prime
    XSE Premium
    I paid $269.24 with tax and shipping to california from Midlands Toyota.
    Where did you find 867A0-47020 for $192.46? Used?
    Some sites I have noticed sell just the camera from salvaged Prii like this one here which in the photos shows the Toyota model number for the camera assembly on the camera itself which if I understand the numbers correctly is not accurate since it should include the plastic mounting piece as well.
    Continuing to look into the digital rear view mirror models available I found one from Toyota with a built in DVR 87840-0W210 ($706.62 impex). Mirror from a Toyota Harrier.
    Has a micro sd card slot on the bottom side of the mirror.
    Wiring harness looks a little different.
    I have come to the conclusion that the two 4 pin connectors on each side are for connecting the front and rear cameras for DVR. Still working on figuring out the other 8 pins. I know 2 are for power one connected to accessory/on 12V power and the other a 12V always on power source, a third for ground. The other 5 pins still a bit of puzzle.
  9. otatrant
    240
    156
    San Francisco
    2023 Prius Prime
    XSE Premium
    Another possibility is that models with rear parking assist with automatic braking use data from a higher resolution camera to detect objects behind the car. A couple of pieces of evidence to support this theory. I attached a hitch mounted bike rack. Somehow the rack would trigger the automatic braking when reversing. Make sense that the camera view of the rack triggered the brake. Another piece of evidence to support this theory is the trims and the inclusion of this feature certain trims. For the 6 trims for the Prius (LE, SE, XLE, XSE, Limited, XSE+) only the upper four trims have this feature included and it is an option for LE and SE trims.
    Here is a pic.
  10. Hammersmith
    2,181
    2,185
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Camera Assembly, Television & Inner Mirror
    Lewis's price is currently $240.57 (free shipping and probably no tax if purchased outside of Kansas). In a couple weeks, it's almost certain autoparts.toyota.com will have a summer/4th of July sale. It might be a 15% off sale, but I'm betting it will be 20% off. That brings the price down to $192.46.
    As for why the camera has the part number printed on that should be for the combined assembly, that I can't tell you. All I can go by are the part diagrams, which say 30040 is for just the camera and 47020 is for the camera plus the assembly.
    otatrant likes this.
  11. KMO
    KMO Senior Member
    1,882
    641
    Finland
    2023 Prius Prime
    Yes, makes sense. Parts descriptions mention it too. Camera presumably required for either PKSB or panoramic view. Wide angle important for both as well as resolution.
  12. Hammersmith
    2,181
    2,185
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, I think you've got the right idea. I screwed up in my thought process and mixed up which system the washer was connected to. I was thinking it was the Panoramic View system when it's really the Rear Mirror system. That caused me to sort them wrong.
    So Japan and North America get both the good and bad versions depending on trim and options, but Europe only gets the good ones.
    I do wonder about the really expensive ones. There are a pair of cameras that are only specced for Japan and Europe that are five times more expensive than the part numbers that have been talked about so far. One of them makes reference to front and rear dashcam/recording. I'm absolutely not interested in ordering one to find out what it is, but I am a little curious.
    867B0-47060 and 867B0-47080.
  13. KMO
    KMO Senior Member
    1,882
    641
    Finland
    2023 Prius Prime
    The Japanese catalogue says the following come as a package option for Z trim:
    • digital rear view mirror
    • front and rear recording
    • recording of rear-approaching vehicles
    with the panoramic view being standard in Z trim.
    The "back guide monitor" is standard on G and U (a display with guidance lines based on the wheel). That's not part of the base US spec, is it? But I guess we still can't be certain whether that's using a high or low-res camera.
    The base Z would presumably have 47180 for the panoramic view.
    So maybe the recording option is that most expensive camera? But not sure why you'd need a more expensive camera for recording.
  14. otatrant
    240
    156
    San Francisco
    2023 Prius Prime
    XSE Premium
    According to the parts department at Pat Lobb Toyota of McKinney my Prius Prime XSE premium with no panoramic view monitor or digital rear view mirror or rear camera washer the replacement part is 47150.
    I have placed several orders for 867A0-47020 but still do not have one yet. The second to last order I placed says it is backordered. Switched to 86790-47190 and paid $133.39 with no tax or shipping with 4th of July sale at Lewis Toyota. Thanks Hammersmith! Within a couple of days I should find out if they have it in stock.
    I have come to realize Hammersmith had it right in his original post. 47150 is standard reversing camera only with no washer while 47180 is back up camera with washer.
    Pretty sure I was wrong about any of the cameras on the rear of the vehicle providing input to rear parking assist with automatic braking since from looking at the wiring diagrams for the advanced park system there is no input from any digital camera rather just ultrasonic sensors.
    Sounds like the digital rear view mirror I mentioned above also used on the Japanese Harrier SUV. From what I can tell it has DVR in the digital rear view mirror that takes a micro SD card. No Homelink which makes it quite a bit cheaper.
    My takeaway so far. There is no difference in camera resolution as far as I can tell. The two different cameras panoramic/reversing and digital rearview mirror differ mainly in the lens with the panoramic/reversing camera more of a wide angle lens and the digital rear view mirror camera more of a standard lens.
    #14 otatrant, Jul 4, 2025
  15. otatrant
    240
    156
    San Francisco
    2023 Prius Prime
    XSE Premium
    Update-
    86790-47190 arrived today. Not what I expected. Good news is that it does have the attachments for the digital rear view camera. Bad news it does not include the digital rear view mirror camera. Here is a photo.
    Here is a photo of the reverse camera with a part number which does not come up in a quick google search.
    Looks like 47190 on first inspection has the holes for the rear camera cleaners too.
  16. Hammersmith
    2,181
    2,185
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    What did you expect and why would you think it would come with the 2nd camera?
    Quoted from an earlier post in this thread:
    Sure, but the only way to get the washing parts is to buy the 47180 part. You can't buy them separately anyway.
  17. otatrant
    240
    156
    San Francisco
    2023 Prius Prime
    XSE Premium
    I realized it is kind of a crapshoot with no clear definitive source on what part number included what camera and washer mounts. What I have is clearly not exactly what I wanted but it is workable. Will need to think of some way to plug the washer holes or the part numbers for the washing spouts.
    If you live in the UK looks like through aliexpress Hassauto Store you can get 867C0-30040 digital rearview mirror camera for £35.99
    After searching online just purchased from Lewis Toyota. No sale this time. Probably be at least a couple months before I install it since I still haven't decided on which mirror to get or how I am going to route the wires.
    This is not 100% correct. 86790-47190 is what I purchased from lewis toyota and received. It includes the ports for the two camera washers.
    This make sense to me.
    That looks correct to me to. Probably would have been better off sticking with this order.
  18. Hammersmith
    2,181
    2,185
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Your picture doesn't show any washer(and there's only one). Did the parts come in the bag or something and you just didn't include them in the pic? The washer goes in the hole in the upper left.
    What I'm saying is who cares if the plate came with the slot for the washer. If you don't have the actual washer nozzle(which comes with the 47180 version), what good does it do you?
  19. otatrant
    240
    156
    San Francisco
    2023 Prius Prime
    XSE Premium
    Two nozzles. One for each camera. Here is another picture to better show the mounting holes for the nozzles.
  20. otatrant
    240
    156
    San Francisco
    2023 Prius Prime
    XSE Premium
    For future reference here is a good pic of 86790-47150 which I am pretty sure what I have installed on my car Prime XSE Premium without panoramic view monitor or digital rearview mirror.
