Is there a P/N for the rubber piece on the hatch outer handle
Discussion in 'Gen 2 Prius Main Forum' started by Kzbd, Jun 11, 2025.
  1. Kzbd
    Kzbd Junior Member
    For my 2007? I am sick of looking at shitty websites that are slow to load and just list every part on the back door but won't show me a diagram. Partsouq only shows the whole switch part number 84945 and to refer to figure 84-20 which I don't find anywhere. There are a bunch of parts like rear handle outer seal which makes me thing the boot would have been an available part at some point.
    That boot has gotten sticky now and makes my fingers black when I open it. I tried putting some wurth's on it but it made it worse.
  2. Tombukt2
    13,290
    2,398
    I do not know the part number but Google and Amazon both have plenty as does eBay . I've ordered a few fakes work quite well .
  3. Tombukt2
    13,290
    2,398
  4. Tombukt2
    13,290
    2,398
    It's actually hard to fek that up
  5. Kzbd
    Kzbd Junior Member
    What do you mean? I'd like to try the Toyota part if one's available.
  6. Kzbd
    Kzbd Junior Member
    The fact that you've ordered a few is concerning.
  7. Tombukt2
    13,290
    2,398
    I have four cars and work.on for folks . I've not had to replace a replacement yet. Usually folks blow up cars . Need batteries or actuators . Not doing that etc.
    Kzbd likes this.
  8. Tombukt2
    13,290
    2,398
    Amiyama.com. Gen 2
  9. Tombukt2
    13,290
    2,398
    Maybe it's the 84840-47020 that might be assembly
    xw20_driver likes this.
  10. Hayslayer
    Hayslayer Active Member
    445
    262
    Because the one Toyota installed on your car has worked out so well? Every 2007 I've owned or worked on had the gummy rubber.
    Like Tom, I've done many of these. The inexpensive ebay kits work perfect. I keep a couple handy. You really want to put some effort into cleaning the button first to remove all the gummy rubber from Toyota's F-up. I remove the garnish and button, use a small pick and AutoZone brake cleaner on a rag to get it like new before installing the new rubber boot. Many people just clean the goo off and leave it like that.
    Kzbd likes this.
  11. xw20_driver
    xw20_driver Member
    95
    51
    PNW
    The official part number appears to be 84840-47020 if your Prius has smart entry or it's 84840-47010 w/o smart entry. It doesn't appear Toyota sells just the rubber cover. Like other suggestions, they sell aftermarket replacement rubber cover on Amazon and Aliexpress.
  12. PriuSocal
    PriuSocal Member
    289
    52
    SoCal
    I second @Tombukt2 , I purchased a replica rubber button cover a few yrs ago off Amazon and til this day its still good as new. only held on by 2 philips screws. Not ignoring your original P/N request just thought id chime in.
  13. Tombukt2
    13,290
    2,398
    I'm not sure that Toyota offers that as a replacement I think you buy the whole button assembly with the wire in the plug on it and the opaque piece of plastic that it sits over I do believe. But you can aftermarket it . Looks rubber to me no vinyl
