TPMS Constant Flashing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PitKempo, Jun 23, 2025.
  1. PitKempo
    PitKempo New Member
    I’ve done a bit of searching but couldn’t find an answer:
    dealt with a “60 second flash then goes solid” light for awhile. Shop diagnosed one bad sensor, mentioned another was low.
    Had them replace the one and they said to drive it for 20 miles or so and it should go off. That didn’t work.
    Took it back to them and they said another was dead. Replaced it (free of charge) but they still can’t get the light to go away. They said they tried everything from programming them and so on and finally mentioned I should take it to Toyota as it could be a bad TPMS module or that it needs to be programmed by them or maybe the old TPMS module can’t detect the new sensors? Idk, they seem at a loss.
    Well now my tire light no longer flashes then goes solid. It’s a faster flashing and doesn’t stop.
    Any ideas before I go the route of electrical tape over the light?
    Thanks in advance!
  2. Tombukt2
    13,110
    2,352
    4 sensor Toyoda branded 45 bux replace all of em in 1 go . I do it every 5 yrs or so . Or play whack a mole. Amazon and eBay in red boxes w logo
  3. ChapmanF
    18,301
  4. PitKempo
    PitKempo New Member
    The shop didn’t mention any trouble codes unfortunately. They replaced two of the 4 sensors at this point and have tried programming them and using their tool to reset everything. No joy there.
  5. PitKempo
    PitKempo New Member
    Are you saying that just replacing 1 or 2 sensors could cause the light to not clear and that you have to replace them all at the same time?
  6. Mendel Leisk
    41,628
    Yes, just say to yourself, “what happens if I do nothing?”
  7. Tombukt2
    13,110
    2,352
    Nope I'm im saying as you do them 1 by 1 you'll be getting back to the first 1 to do it again and so on . That's slot of wheel breaking down at say 20 bux a pop
  8. Tombukt2
    13,110
    2,352
    Well yes that could actually happen if you change the wrong two sensors or. Give it a think for a few minutes.
  9. ASRDogman
    ASRDogman Senior Member
    7,647
    3,936
    Perhaps they replaced the wrong ones????
    You can replace one at a time. Usually, but not always, when one goes, the others soon follow.
    Maybe there equipment can't read/write to Toyota's computer.
    You can try another shop, parts store, or walfart.
    The old ones need to be deleted, then the new ones added.
    Some equipment is able to reprogram the new sensor with the dead sensors number.
  10. Tombukt2
    13,110
    2,352
    Royalty Auto service See Sherwood Dr he will walk you thru it
  11. ChapmanF
    18,301
    The link I put in post #3 will show you a way to get the trouble codes yourself. Then we can be talking about what is happening, instead of about what might be happening.
  12. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    Ever figure this out? Mine is constantly flashing about 2 weeks after getting all new TPMS sensors/tires. Worked fine at first anyway. Had a mechanic check quickly and they are all functioning fine. Wonder if I need to bring it back to the tire shop to be repaired or something.
    Interestingly enough, "constant flashing" is not mentioned in the Owner's Manual at all.
    #12 VicVinegar, Jul 9, 2025
  13. ASRDogman
    7,647
    3,936
    The old ones must be deleted and new ones programed in.
    Or the new ones need there id code changed to match the original ones.
  14. VicVinegar
    VicVinegar Member
    275
    53
    Northern Virginia
    The light was off for the last 2 weeks, so it seemed like the tire shop had done its job at least at the time. I turned it on after being in the shop for something else today and the light is flashing.
    Sounds like I should call the tire guys again.
  15. ChapmanF
    18,301
    I'm not sure I've ever seen "constant flashing" be a thing it ever does. I have seen "constant flashing for a whole minute, then on solid", though, and that is in the owners' manual.
    The link upthread in post #3 will show you how to get the trouble code(s) indicating why that is happening.
    Brian1954 likes this.
