What Type of Charging Port/Connector?
Discussion in 'Prime Plug-in Charging' started by PG7000, Jun 22, 2025.
  1. PG7000
    PG7000 New Member
    NY
    2025 Prius Plug-in
    2025 Prius PHEV Limited
    I can't find this ANYWHERE in ANY of the manuals? Maybe it's there, But I can't find it.
    I need to order a Level 2 charger and I don't want to buy the wrong one.
    Thanks!
    52,337
    SAE_J1772 they are all one standard except tesla believe it or not. you need an adapter for their superchargers.
    get whatever you like, you can't go wrong
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    You might want to check out the Gen 5 Prius section on this forum. It's listed under the Prius tab. There is no separate section for Gen 5 Plug-in Hybrids like for Gen 4 and earlier.
  4. bisco
    52,337
  5. PG7000
    PG7000 New Member
    NY
    2025 Prius Plug-in
    Okay, thank you.
