My head gasket diagnosis pictures - 3 years ago
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by themzlab, Jun 24, 2025 at 1:09 PM.
  1. themzlab
    themzlab Junior Member
    Wisconsin USA
    3 years ago, at ~180k miles my 2013my head gasket failed. It had some stumbling going away from stop signs and maybe at cold start and a misfire code. It also had minor coolant loss. The problem wasn't noticeable for very long before I did the repair - probably just a matter of a few weeks.
    The car has 230k miles now and is doing really well.
    Before I took the engine apart, I also looked inside the combustion chambers with a borescope and noticed a drip of water going down the side of cylinder 1. This roughly correlates to the spot I saw once I had the thing apart and noticed bare spots in the gasket. unfortunately, I didn't save those pictures.
    I used a block test kit to 'confirm' the failure though I think there was plenty of other evidence of the problem.
    I have had the car since around 20k miles and it is well maintained. We use this car preferentially for short trips, so the 180k miles were relatively high duty cycle of starts/stops which I think is the big factor in wearing the gasket.
    bisco and Mendel Leisk like this.
  2. Mendel Leisk
    40,502
    Block test will only be positive when 3rd gen Prius head gasket failure is well along. It tests for carbon monoxide in the coolant, which doesn't happen in the early failure stages, it's typically coolant leaking into combustion chamber(s).
