My head gasket diagnosis pictures - 3 years ago
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by themzlab, Jun 24, 2025.
  1. themzlab
    themzlab Junior Member
    28
    Wisconsin USA
    3 years ago, at ~180k miles my 2013my head gasket failed. It had some stumbling going away from stop signs and maybe at cold start and a misfire code. It also had minor coolant loss. The problem wasn't noticeable for very long before I did the repair - probably just a matter of a few weeks.
    The car has 230k miles now and is doing really well.
    Before I took the engine apart, I also looked inside the combustion chambers with a borescope and noticed a drip of water going down the side of cylinder 1. This roughly correlates to the spot I saw once I had the thing apart and noticed bare spots in the gasket. unfortunately, I didn't save those pictures.
    I used a block test kit to 'confirm' the failure though I think there was plenty of other evidence of the problem.
    I have had the car since around 20k miles and it is well maintained. We use this car preferentially for short trips, so the 180k miles were relatively high duty cycle of starts/stops which I think is the big factor in wearing the gasket.
    wheelsup, bisco and Mendel Leisk like this.
  2. Mendel Leisk
    41,850
    Block test will only be positive when 3rd gen Prius head gasket failure is well along. It tests for carbon monoxide in the coolant, which doesn't happen in the early failure stages, it's typically coolant leaking into combustion chamber(s).
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,725
    1,762
    Bay Area
    Did you have your cylinder head valves lap and stem oil seal replaced? Or you just replaced the headgasket and put everything back?
  4. themzlab
    28
    Wisconsin USA
    I didn't do any work to the head or block other than clean up what I could do at home. I know that best practice would be to take the head to a machine shop. My engine had not overheated or had anything else obviously bad happen to it, so I took this shortcut. I did have the pertinent factory pages and I followed the instructions for the sealing materials fairly closely. I used torque wrenches on most things. My point is that other than not going to a machine shop, I tried to do this slowly and correctly.
    Bear in mind, this was 3 years and 50k miles ago so I have at least gotten away with this for that long.
    NutzAboutBolts likes this.
  5. NutzAboutBolts
    1,725
    1,762
    Bay Area
    well, that gives me hope to not bring it to a machine shop if my cylinder head and block is straight and not warped. Maybe I’ll check the valves for leaks and see if it needs lapping or not I’m lazy as well and want to do the bare minimum. Let’s see how bad my head is in a couple of days.
