2012 Prius V w/P0177 code
Discussion in 'Prius v Main Forum' started by Franco7x, Jun 25, 2025 at 3:12 AM.
  1. Franco7x
    Franco7x Junior Member
    2012 Prius V, 179k miles, today I had the motor stammer/stutter after sitting with AC on for about 5 minutes. i
    It has never happened before, I shut it down for several minutes, checked the oil, coolant level, and looked for any disconnected thing but all was fine. So I restarted it without the AC just to eliminate that from the equation. It ran fine again, so I headed to Advance to check the code which showed the Coolant Temp Sensor.
    i didn’t want to buy their brand so decided I would get an oem one tomorrow. Before I reached home it did stutter again while driving almost like it was about to die.
    Managed to make it home.
    I do remember one thing about a week ago, I was rushing to the airport late at night to pick up a friend, I drove it harder than I usually do about 80 miles an hour for about 5 minutes. I saw a red light flicker on the dash so I immediately reduced my speed and it stayed gone, never returned. The next morning checked the coolant level and all was fine. But now I am thinking that maybe this is related.
    I did do a coolant flush back at 80k. The only non routine repair was doing the brake actuator replacement costing nearly $3k.
    i realize I am at that stage where things will begin to fail on a Toyota. It is due for a new set of plugs since I did them at 80k as well.
    After some reading here, I am thinking that possibly the water pump should be replaced. could these 2 things be the engine stutter culprit?
    there is no coolant loss and the oil look like honey, no milkshake.
    I will order from amazon an autel ap200 to help my diagnostics here, the ap2500e seems to jave worse reviews. Open to any suggestions on other code readers around $100 or less.
    Also where is the location of the Coolant Sensor? All youtube vids just show a standard gen 3.
    thanks in advance.
    #1 Franco7x, Jun 25, 2025 at 3:12 AM
  2. Brian1954
    Brian1954 Senior Member
    1,746
    681
    South Central PA, USA
    I think the P0177 code is a typo. The code for the engine coolant temperature circuit low input is P0117. When you get this code, it does NOT mean that the temperature sensor needs to be replaced.
    Based on your description, It appears that the engine overheated and caused the P0117 code. My guess is that the engine water pump is going bad. Preferred replacement is a Toyota OEM pump.
    The Autel AP200 is an excellent choice for a scanner for the Prius. It is capable of reading all the trouble codes in your car. Once you get the scanner, follow all the setup instructions. You will need to create an Autel account. After doing the setup of the scanner, run a complete diagnostic scan and see what you find.
    The next step is to use the scanner to run an active test of the engine water pump. This will run the pump at 3000 rpm, and you can see what the actual speed of the pump is versus the request speed of 3000 rpm. You may find that the actual speed is lower than the requested speed.
    You can also use the scanner to monitor the engine coolant temperature when you are driving. Normal temperature at highway speeds is 195F. When you use more throttle like going up a hill, the temperature could rise to 199 to 201F. If your temperature is going higher than 201F on the highway, I would replace the water pump.
    Franco7x likes this.
  3. ChapmanF
    17,252
    ^ This. For a little more explanation, the sensor is a "negative temperature coefficient" thermistor, meaning its resistance goes lower as the coolant gets hotter, and that's why a code whose fortune cookie reads "engine coolant temperature sensor low input" can be telling you the coolant was hot.
    To set the code, the reading has to be off-the-scale hot, so hot that the ECM thinks it could be an electrical problem and not a real reading. (Which it could be, say if the sensor wiring is damaged and shorting to ground.) But if it is a real reading, it's a very hot one.
  4. rjparker
    9,563
    5,869
    There are two coolant temperature sensors, one under the egr on the engine and another on a hose under the wiper cowl, driver's side.
    The hose mounted sensor is found in the Combination Meter ecu. The engine mounted sensor is read by the ECM ecu.
    You reached 248f or higher in an engine that normally never exceeds 204f worse case unless a water pump code exists which causes a lower temperature alarm.
    Start up rattle is not an overheating symptom. Sometimes a head gasket leak will add combustion gasses (burned or unburnt) into the cooling system causing a loss of cooling efficiency.
    The blink and gone on the temperature light is too common which makes monitoring temperature more important if you chose to drive it. Personally I would not drive it much because a) a water pump failure is bad or a b) hg leak is worse because it can cause overheating as well.
    A code reader is not definitive on a hg leak even if it can access all ecus on a Prius, something an auto supply scan can not do.
    I believe a dual view borescope inspection can be definitive of hg problems which are common on gen3s. Finding a hybrid specialist in your area is the best bet. Unfortunately "Texas" is too big to offer shop recommendations since it can take up to 12 hours to get from one city to another.
    Car Care Nut HG Borescope at 660s
  5. Franco7x
    Yes, that was a typo. Sorry about that.
    The scanner will arrive tomorrow morning early, hope to get an early start on it.
    On Friday the new Aisin water pump is scheduled to arrive.
    Today, I did notice that the coolant level was low. So that has me stressed.
    I replaced the front brakes while waiting on the scanner and water pump.
    When I got took the car out to bed the brakes, the car is stammering upon acceleration. After a few runs of bedding it went away but the motor definitely feels different. Is it possible that the coolant does not need replacement? I have not ordered one or a thermostat yet.
  6. Franco7x
    So it is best to order a new coolant temp sensor as well.
    Ok, I will replace it too. Is it near the firewall?
  7. Franco7x
    Hello RJ,
    I was hoping you would lend your expertise, thanks.
    Which of those 2 sensors gives me that code?
    I was wromg about not losing any coolant, today I needed to add some. And the stammer is happening more frequently.
    I am not driving it now. But I feel that, while necessary, a new water pump is probably not going to resolve this issue.
    I am in the Houston area, but since I have AAA plus I can have it towed as far as Austin if there is a better shop there.
    Even if I need a new hg, the water pump is something that needed replacing.
    But I do need my car up and running sooner rather than later. I hope I didnt do any real lasting damage.
  8. rjparker
    9,563
    5,869
    Either could code and it's my understanding the light will come on from either. Normally they stay within a couple of degrees of each other.
    My bet is the cooling system is lower on coolant than it appears which is causing the warning.
  9. ChapmanF
    17,252
    It seems unlikely to me that either coolant sensor would be at fault. The sensors are thermistors and I can't say I've even heard of one going bad.
    If the code was set, it probably means either that the coolant really did get that hot (in which case there's nothing wrong with the sensor, just doing its job), or (2nd place guess) that the wiring to the sensor may be damaged and shorting to ground somewhere.
    The likelihood of any problem with the sensor itself, I would rate a distant third.
  10. Franco7x
  11. Brian1954
    1,746
    681
    The P0117 code is for the engine coolant temperature sensor. This is the sensor that is installed in the engine block.
    With the engine not running right and coolant loss, I would not be surprise if you have a bad head gasket.
