Gen 2 (2008) Prius keeps showing red car with exclamation mark, no codes showing up.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JoeDog99, Jun 22, 2025 at 6:58 AM.
  1. JoeDog99
    JoeDog99 Junior Member
    30
    I had my break pads changed and they are working fine.
    However now the multi media display keeps showing a red car with an exclamation mark on it.
    The hybrid battery was just replaced a few months agao and charges without issue.
    And the 12v is also testing as good.
    The car is turning on and driving fine without issue and not making any weird noises or struggling to drive.
    2 seperate mechanics have tried reading the codes but nothing shows up (yes, they have the right tool and have read codes for me before)
    I also just replaced the air filter.
    So any ideas on what the issue might be?
  2. JoeDog99
    30
    Also...yes, i have tried restarting it by disconnecting the 12v but the light goes away for a day or two but then returns.
  3. ChapmanF
    17,217
    Please post the make and model of the right tool that they have.
    How much engine oil shows on the dipstick?
    Brian1954 likes this.
  4. JoeDog99
    30
    I am not sure the make and model of the tool they have but in the past they have read codes and fixed issues including scanning hybrid battery to see if all the cells were good when i purchaced it
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,950
    1,902
    NJ-USA
    The only information I have from the owner's manual is that icon indicates a fault with something in the hybrid drive system. Usually I would expect such a problem to trigger the "master caution" (red triangle) as well.
    If someone has done a "system scan" for codes, I would want to have a copy of the results. Specifically a list of all 15-16 systems on a Gen 2, with each one saying that it did not have codes present.
    You can also consider getting your own scantool and checking things when the fault occurs.
    Here's a thread that reviews several options for smartphone. The synopsis is post 37. The Autel AP200 is a decent choice of capability vs price.
  6. Tombukt2
    12,085
    2,134
    Go out and put your hand on the inverter pump while the car's ready on. If it's not vibrating that's it.
    ColoradoCrow likes this.
  7. ChapmanF
    17,217
  8. JoeDog99
    30
    I did try this and felt no vibration. However within a few minutes the car completely shut down and will not shift now
    The ready light and hybrid battery on the multi media display still show up so I'm guessing the inverter blew?
  9. JoeDog99
    30
    There was also a suction cup pump type noise for a few moments before it out out.
