OEM spare tire install
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Hammersmith, May 31, 2023.
  1. Ahimsa9
    Ahimsa9 New Member
    St Louis, MO
    2024 Prius
    Thanks for updating us on the decals. I called my local dealer and found out they're still waiting on the door jamb decal as well. Just like your situation, I was originally told it was backordered with no ETA, then I was told today that it would arrive by July.
    I looked back through the thread to find the warning triangle part number with no luck. Do you have that number handy? Also, does it take 3 of them to fill up the slot on the right side of the foam?
  2. Hammersmith
    Hammersmith Senior Member
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    81604-WAA01
    You can make an argument for 2, 3, or even 4. If you look at your foam, 2 triangles will come up to exactly the level of the jack cutout. 3 triangles come up to exactly the level of the cutout that makes removing the 12V battery cover easier. I think 4 would come very close to the absolute top of the foam. I went with three because I think that's what the European owners on here said came with their cars. I don't know for certain if the version we get in the US is exactly the same as they ship to Europe, but it's what we've got.
    Length-wise, the triangles don't fill the slot, but I wonder if that's deliberate so you have room to get your fingers in there to pry them out.
    Ahimsa9 likes this.
  3. KMO
    KMO Senior Member
    2,003
    728
    Finland
    2023 Prius Prime
    Never thought of having more than one myself - and mine only came with one.
    In Japan they also have a flare, but that's stored in the passenger footwell.
    (No, Hammersmith, you don't need one. Close the parts database.)
  4. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Good to know about the number. A quick google search says the EU requires one, but Spain requires two.
    Maybe I subconsciously chose three because that's the US requirement for semi trucks. And it's what I've seen when I've seen them in use.
    As for the flare, I'm tempted, but probably not. lol
    I can't tell if the JDM trim board has a built-in bracket for the flare, or if it's just attached with double sided tape. Plus I don't know if the LH trim from a RHD car will fit on a LHD car. The trim piece is only about $22+SH, so it wouldn't be a huge waste of money, but I doubt I make an order just for it. But if I ever need to order from Japan again, I'll probably include it just to be dumb.
    The part number for the JDM LH trim panel is 62112-47240-C0. Not sure what the part number is for the flare itself. I couldn't see it in any of the part diagrams.
  5. KMO
    KMO Senior Member
    2,003
    728
    Finland
    2023 Prius Prime
    I seem to recall that with your deck board "-C0" indicated "foam blocks stuck on", so maybe here it indicates "flare clip stuck on"...
  6. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No, I think in most cases with interior components, a suffix like -C0 means color. In this case, black. The US version of the same part is 62112-47250-C0.
    When I was doing the research for my seat conversion, the pattern was:
    1st five digits = what part of the seat/car (e.g. front headrest, RH front seat bottom, LH rear seat back, etc.)
    2nd five digits = which version of the part (JDM, USDM, vinyl, cloth, manual, power, etc.)
    suffix = color (grey, black w/silver stitching, black w/red stitching)
    Ahimsa9 likes this.
  7. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm weak. :(
    I ordered the parts to add the FCTA sensors, so I went ahead and ordered the trim panel as well. When the importers get back from Golden Week holiday, I'm going to ask them to include an emergency light(can't find a Toyota part number for one). I don't love the idea of a traditional flare right next to my leg, so I'll go with an LED one.
    I'm fairly sure it's not going to work too well on a LHD car, as it might interfere with your left foot when you place it on the dummy pad. And that's not even considering if the trim piece from a RHD car will fit in a LHD. But it's less than 20 euros to try, so it'll be a fun experiment.
    Worst case, I'll have a flashing LED light I can throw into my existing emergency kit.
  8. hill
    8,894
    Would LOVE it if collapsible spares were available from more manufactures other than the likes of porsche/audi/VW & BMW .
    #488 hill, May 6, 2025
    tat2boy likes this.
  9. Templeton
    Templeton Active Member
    321
    114
    usa
    2024 Prius Prime
    SE
    Have not seen those before. That is a wild concept. I wonder if there are any significant downsides of this kind of spare?
  10. hill
    8,894
    Don't know about significant, but you have to make sure the accompanying compressor is working, & like donut spares - maximum speeds are lower. collapsables are typically 50 mph.
  11. BIDTOYO
    BIDTOYO New Member
    28
    Boise
    2025 Prius
    Will the jack from a 2010 to 2015 part number 09111-47050 fit a 2025 Prius LTD AWD ?
    These older jacks are readily available on eBay and are 1/2 or less the price of the newer parts?
  12. Blackat
    Blackat Active Member
    475
    335
    Colorado
    2023 Prius
    Limited AWD-e
    Almost any jack will work. I use the one from my 2017 VW Alltrack
  13. daisy555
    daisy555 Senior Member
    1,727
    715
    CT
    Seems strange that an extra 40lbs would cause this to happen especially since the spare tire kit weight isn’t directly above the passenger side. Hopefully you were just tripping. : }
    I’m purchasing my parts this weekend. Triple checking my part numbers so I don’t have to make any returns.
    Gorgonzola likes this.
  14. Ahimsa9
    Ahimsa9 New Member
    St Louis, MO
    2024 Prius
    Yeah, I didn't compare the clearance on each side before the conversion, so it may have already been different. The only thing I could come up with is that the spare and jack components add a slight amount of extra weight to the driver's side (not passenger side as I originally stated), due to the offset spare tire well, so I was thinking this factor may have contributed to the slightly lower amount of clearance I have on that side. It's still that way, but I find I'm tripping a little less about it these days. :} Good luck with the conversion! It's worth the peace of mind.
    daisy555 likes this.
  15. Paul Gregory
    Paul Gregory Senior Member
    2,212
    584
    Alberta
    2024 Prius Prime
    XSE
    My tire went flat from uneven wear, caused by a misalignment, caused by hitting a curb.
    The dealer claimed it was because it had too much weight in the car.
    Next time, I get the alignment checked when I hit something.
  16. daisy555
    1,727
    715
    CT
    That’s a bummer. How hard did you hit the curb? Too much weight in the car? What kind of weight?
    I very gently (not intentionally that’s for sure) rolled up onto a rounded edged curb in a parking lot. Felt like slowly driving over a speed bump rather than hitting a curb so I’m hoping I’m fine.
  17. daisy555
    1,727
    715
    CT
    Thanks. My new car jitters have not faded yet. I parked in a spot I thought was quiet and shady thud morning. Turns out I arrived right before all the camp drop offs. Loads of cars parking next to my car with kids and their sports gear. : )
  18. Paul Gregory
    2,212
    584
    Alberta
    2024 Prius Prime
    XSE
    I was only moving at a walking pace, but apparently it's easy to knock the wheels out of alignment. I guess that's why the rear passenger blew; it was wearing on the edge. and probably got too thin. The wheel was a long way out of adjustment, "2.32" whatever that means.
    The car was not overloaded. Dealers always think they have an answer for everything.
  19. GeoJ
    GeoJ Active Member
    205
    187
    United States
    2023 Prius Prime
    XSE
    How many miles on the tire, and, how many miles driven after the incident that cause misalignment ? Curious. Thanks.
  20. Paul Gregory
    2,212
    584
    Alberta
    2024 Prius Prime
    XSE
    I'm only guessing, because I don't which impact caused the misalignment, but it was a few months for sure. The dealer said it was causing the edge of the tire to wear off.
