2010 Prius, 12v battery or key fob battery? "Key fob not detected"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wheelsup, Jun 26, 2025 at 8:35 PM.
  1. wheelsup
    wheelsup Junior Member
    96
    Raleigh, NC
    Key fob not detected message.
    • 12v battery measures ~12.2v-12.3v resting after sitting for three or four days. It's ~10 years old. AGM. Tests ~50% capacity.
    • Key fob battery is 3v. Measures 2.8v under 470Ω load.
    Wondering if this is the 12v battery or key fob...while I know I could replace the 12v I'd hate to do it without a reason.
    Normally key fob says "key battery low" IIRC, so this has me questioning the 12v.
    Also my local dealer is around $170 for their battery, claiming it fits the 2010 Prius. Is this correct and a decent price?
    51,066
    sounds like either/both, but might as well start with a fresh fob battery. 10year old 12v? i would replace it if it were me. idk if that is the right size, but it is a great price.
    wheelsup likes this.
  3. ASRDogman
    ASRDogman Senior Member
    7,172
    3,756
    Best to replace the 12v battery, it will soon start giving you hybrid errors.
    Make sure you charge it for 4-5 hours at 5 amps or less to give it a full charge before
    installing....
    Key fob batteries are inexpensive, won't hurt to change it...
  4. wheelsup
    96
    Raleigh, NC
    I have a Noco Genius 5, so will put it on that before putting it in the car. Thanks.
    ASRDogman likes this.
  5. Brian1954
    Brian1954 Senior Member
    1,741
    679
    South Central PA, USA
    You need to replace the key fob battery. 2.8 volts for that battery is very low. A new CR1632 battery should measure about 3.3 volts.
    I just replaced my wife's key fob battery today because she got the same "Key fob not detected" message. She said she had to hold her purse close to the dashboard for the car to detect the fob. I measured the old fob battery at 3.00v, and the new battery I installed was 3.3v.
    The 12v battery you show in your post is the correct one. That is a very good price for the battery.
  6. Paul Gregory
    Paul Gregory Senior Member
    1,439
    372
    Alberta
    2024 Prius Prime
    XSE
    One of my pet peeves is "keep replacing parts until it works."
  7. wheelsup
    96
    Raleigh, NC
    OK I can replace, as I have spares. But just to confirm, that is 2.8v with the 470Ω resistor across it, it's 3v without a load.
    My new ones are around 3.27v as you described.
    That being said, I'd think 12.2-12.3v resting should be more than enough for that 12v to continue service.
  8. Brian1954
    1,741
    679
    I agree. If you already carry a jumper pack in your car, I would wait to replace the 12v battery. If you do not have a jumper pack, I would not hesitate to replace the 12v battery, especially at the price you show in your first post.
  9. ASRDogman
    7,172
    3,756
    :eek::rolleyes::ROFLMAO::whistle:
    Don't think, FEEEEELLLLLL!!!!
    Cause you'd be thinking wrong. In a Prius, that's a dead battery. 12.6, maybe 12.5v is the lowest
    for the Prius computers to function properly. And after 10 years, It's lived a good life and served you well.
    Avoid issues, replace it will a new battery, and charge it.....
  10. Brian1954
    1,741
    679
    That's not true. Can you please provide the link to the Toyota documentation that states that the Prius computers need 12.5v or higher to function properly. I have read multiple posts made by @ChapmanF that the computers in a Prius will function properly with a 12v battery as low as 11.5v.
    My 12v battery has been in the range of 12.4v to 12.2v over the past year or so. It has worked flawlessly. Car starts every time. No trouble codes or warning lights on the dashboard.
    #10 Brian1954, Jun 27, 2025 at 8:59 AM
  11. Paul Gregory
    1,439
    372
    Alberta
    2024 Prius Prime
    XSE
    My car is rendered inoperable when the 12V battery falls to around 11.5 volts.
  12. ChapmanF
    17,238
    The Toyota repair manuals are full of troubleshooting procedures with an early step like this:
    ... which is not, by the way, anything like a statement that anything < 11 V means stuff will go wrong. It means that below 11 V you might want to charge or replace it to rule it out as a problem before proceeding to other troubleshooting steps, whereas between 11 and 14 V you can just go ahead with the other steps.
    I've never seen a Prius start misbehaving until substantially below 11 V. There are some ECUs in the car that will start logging "hey, did you notice the voltage is low?" codes around 9.5 V. (Those ECUs, of course, are at that point still working fine, and executing their programming to tell you about the voltage reading they noticed.)
    A Prius that "is rendered inoperable" "around 11.5 volts" has something mighty unusual going on.
      File size:
      1.9 KB
    Brian1954 likes this.
  13. Paul Gregory
    1,439
    372
    Alberta
    2024 Prius Prime
    XSE
    You'd think...
    But the dealer disagrees. They blamed me for draining the battery by using a cellphone or some stupid such stuff.
    I have left my car parked for as little as 2 hours, to return to it, unable to start, requiring a boost. I think it's due to the wireless updates, which are unpredictable.
  14. bisco
    51,066
    you need to have the 12v load tested if you don't want to replace it. you can get a free test at many auto parts stores
