Getting conflicting answers on google about how much oil is needed to do an oil change.
Discussion in 'Gen 3 Prius Technical Discussion' started by h1ph0panonymous, Jun 20, 2025.
  1. jdenenberg
    jdenenberg EE Professor
    3,921
    1,918
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My Toyota dealer (A1 in CT) does free oil changes for cars bought at their dealership (at 10k mile intervals, If I want it done more often, I do it myself evry other time). I just check the dipstick afterwards to confirm that they filled it to the correct level. They use the correct synthetic oil and Toyota oil filters.
    JeffD
  2. ASRDogman
    ASRDogman Senior Member
    7,170
    3,755
    They charge you because you keep paying them!
    4.4qts is what the manual says with oil filter change.
    Find it in your maintanence book and show them and then tell them you want $15 + tax back
    for each oil change. And any damage from over filling will be on their ticket!
    Grit likes this.
  3. Mendel Leisk
    40,514
    You sometimes see ads worded something like this:
    "Oil and filter changer, up to 6 quarts, $XX"
    Could be something like that, a blanket charge, as long as it's under 6?
  4. PriusTech
    PriusTech Member
    78
    53
    Reno
    Mobil 1 full synthetic. Walmart best bang for the buck
    Toyota factory filter. or Napa Gold or Platinum. There's probably others but Fram and house brands are usually garbage.
    4.4 qts. But run the engine after the change to fill the filter, then recheck the level.
    Beware of the Jiffy Lube places. If you read the fine print on the receipt they are usually not responsible for leaving the drain plug loose or not filling the oil. If you go there at least check the dipstick before driving, and check the pavement where you've been parked for drips/leaks. Keep in mind even if the shop pays for damages its a huge hassle to replace a blown engine.
    Jiffy Lubes will scam you also. They will intentionally strip the threads on your oil drain plug and then tell you that you need a thread repair kit. They are also known for unintentionally over tightening and stripping the drain plug and then also needing a repair. They will also take out a clean premium factory air filter and charge you to put in a cheap Chinese filter that leaks dirt.
    Dealerships (Stealerships) charging for 6 quarts are just padding the bill. The only business I would give this type of dealer would be warranty work.
    #24 PriusTech, Jun 27, 2025 at 5:08 PM
  5. ASRDogman
    7,170
    3,755
    NO SUCH THING as a stealership. NO one is putting a gun to your head. Just say NO!
    I made a lot of money from replacing engine and/or pistons/rings on Hyundai's because of jiffy lube and
    other places like it. A good lawyer will win the case if they try to say they are not responsible for not tightening
    the drain plug. At least here in Florida.
    But no matter what, NEVER go to any of those places.
    Grit likes this.
  6. BiomedO1
    2,756
    1,466
    SacTown, Ca
    Congratulations; you've got the only Prius that has a Camry or TACO oil sump. I believe those has a 5-6 quart oil sump. Bring this to the attention of the dealership management. Tell them your calling the local consumer protection agency and/or local news agencies.
    They'll probably offer up some free oil changes to calm you down.....
    Good Luck..
  7. Grit
    Grit Senior Member
    6,421
    4,182
    Wilkes Land
    Fram synthetic will be fine. I paired it up with redline and blacks tone oil labs said I was safe for 14,000 mi oil interval changes with the filter. It removes up to 20 microns, not the typical 30.
  8. PriusTech
    PriusTech Member
    78
    53
    Reno
    IDK, the last I checked some of the Frams had cardboard ends on the filter element. Maybe they have different levels of quality. But you can't go wrong with a factory part, it's designed by factory engineers.
