2023 LE fwd mpg, what are you getting?
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by 2023p, Apr 24, 2023.
Tags:
  1. 23PearlPrius
    23PearlPrius Junior Member
    Sb County
    2023 Prius
    Yup.
    Anything above 12mpg is a bonus for me. :) Came from a gas guzzler and I drive how I like to drive.
    I'm at almost 15k miles and I was always running around 44-47mpg.
    I recently put on some 19 inch 235s and hitting 42-45mpg now.
    Definitely going to try what Preebee said though--going to turn off my AC for a while. I've never really turned it off since day one as I never considered how it might affect MPG.
  2. Winston Smith
    Winston Smith Active Member
    357
    240
    OH
    2024 Prius
    LE AWD-e
    I turned off the climate control and saw an improvement. Now that it's warmer I go to and from the office along the lake about 15 miles each way and get 70-ish mpg.
  3. phase
    phase Member
    105
    42
    Portland
    2023 Prius
    LE AWD-e
    tell me youre over 60 without saying youre over 60
  4. silvertounged devil
    silvertounged devil Junior Member
    47
    Yorktown Virginia
    2024 Prius
    JFK was assassinated on my 13th birthday.
  5. silvertounged devil
    47
    Yorktown Virginia
    2024 Prius
    Indication over 65 MPG tank average, total range over 610 miles. Just trying to not use the AC. Will be interesting to see what the actual tank mileage sorts out to. best so far closing in on 5k on the odometer. Think I'll pass on the 5 k service or drop and fill the oil without touching the filter. Dealership does it for free at 10k. Base model LE.
  6. BiomedO1
    3,483
    1,807
    SacTown, Ca
    IMHO; you should change the filter too - the OEM filter isn't that expensive. The point of the early oil change is to dump out all the break-in debris, leaving a dirty filter seems to be counterproductive. Kinda like taking a shower/bath then putting your dirty underwear/clothes back on.
    Just my 2-cents.....
    silvertounged devil likes this.
  7. Boerneboy1972
    Boerneboy1972 New Member
    San Antonio
  8. silvertounged devil
    47
    Yorktown Virginia
    2024 Prius
    Tank average measured at the pump is 65.5, even with gas at $3 a gallon that's still under 5 cents a mile. If I drive slower it will sneak past 70 MPG but staying away from idiots usually drops it down into the mid 60's by the time I need to refill the tank. At 5k miles the oil was still full and not even dirty. Most of my trips are better than 50% battery only, even a 100 mile trip to the kids house.
    If it runs more than half the time on the battery, then I can just wait until I get to 10k and let the selling dealership do the oil change for free.
    94 today and I did not turn on the AC, close to 70 MPG even driving normally.
    I can keep it close with the AC on just low fan speed, recirculate, and temp as high as she can stand it. Higher speeds and AC knock it down 5 MPG or a little more if it gets close to 100 outside.
    DTE 632 right now.
  9. Gorgonzola
    Gorgonzola Junior Member
    31
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    By way of comparison, my LE AWD has been averaging about 62-64 MPG per tankful (air temps above 50F, tires inflated to 38 PSI). That’s with use of AC, and mix of driving conditions (no hypermiling by any means), and fairly hilly terrain. When I drive to work, I notice that I tend to average about 70-75 MPG; meanwhile, on the reverse trip I usually average somewhere around 58-60 MPG. The difference is largely attributable to elevation gain/loss (my drive in is mostly downhill, vs. the opposite on the way back), as well as relative time of day and corresponding HVAC use. Honestly, I have not noticed much of a difference in fuel economy between the “Eco” and “Normal” driving modes.
    #249 Gorgonzola, Jun 27, 2025
  10. silvertounged devil
    47
    Yorktown Virginia
    2024 Prius
    408.3 miles on 6 gallons 68.05 MPG. Gas prices dropped like a rock in the last month. COSTCO at $2.69 a gallon.
    $.0448 per mile. A little over 7k on the odometer, going on 7 months ownership.
    johnHRP likes this.
  11. patmine23
    patmine23 Junior Member
    2023 Prius
    At the half tank mark I am at 69.2 mpg. It is mostly start and stop with 2 sections that are 55 mph for about 6 miles. The rest are 45 mph and 35mph with frequent stops. At the half tank mark I have traveled 432 miles, car shows 204 left till empty. This is the best mileage so far with this car. I was hoping to get to the 70mpg mark but I am lazy and didn't want to put in that much effort, nor piss off people driving behind me. LOL
    I will update the exact consumption when I refuel.
  12. johnHRP
    johnHRP Active Member
    643
    185
    KA, DE
    Excel
    The 2.0L is very efficient with dual injectors and aggressive timing and compression, plus the electric motor and inverter are also more powerful in Prius 5. It adds up to achievable 60mpg+ in state roads speed <55mph
