Why such low torque?
Discussion in 'Gen 3 Prius Technical Discussion' started by Paul Gregory, Jun 27, 2025 at 8:23 AM.
  1. Paul Gregory
    Paul Gregory Senior Member
    1,437
    370
    Alberta
    2024 Prius Prime
    XSE
    I don't have anyone blocked at present. Sometimes I don't have a response worth giving.
  2. ChapmanF
    17,238
    As it makes a significant difference to available torque/power whether you are driving forward or reversing, it was worth finally giving your response in post #16 to the question Tombukt2 first asked you in post #2.
    #22 ChapmanF, Jun 28, 2025 at 9:55 AM
  3. Paul Gregory
    1,437
    370
    Alberta
    2024 Prius Prime
    XSE
    I was clear enough the first time.
  4. ChapmanF
    17,238
    There was no first time you answered that question before post #16. Notwithstanding your "as I explained" effort to muddy the history of the thread:
    You had not explained that you "backed into the slot" until post #14, and even in that post you still did not say whether you were trying to drive forward or reverse from that position later, after having been asked that specific question numerous times.
    While "backed up to a shop door" would clearly imply driving away forward if it was a closed door, it's equally clear that a door you could back through far enough for your rear wheels to settle into the door track probably wasn't closed. So whether your next move was forward or reverse from that point was still never answered until post #16.
