Why such low torque?
Discussion in 'Gen 3 Prius Technical Discussion' started by Paul Gregory, Jun 27, 2025 at 8:23 AM.
  1. Paul Gregory
    Paul Gregory Senior Member
    1,442
    374
    Alberta
    2024 Prius Prime
    XSE
    I don't have anyone blocked at present. Sometimes I don't have a response worth giving.
  2. ChapmanF
    17,238
    As it makes a significant difference to available torque/power whether you are driving forward or reversing, it was worth finally giving your response in post #16 to the question Tombukt2 first asked you in post #2.
    #22 ChapmanF, Jun 28, 2025 at 9:55 AM
  3. Paul Gregory
    1,442
    374
    Alberta
    2024 Prius Prime
    XSE
    I was clear enough the first time.
  4. ChapmanF
    17,238
    There was no first time you answered that question before post #16. Notwithstanding your "as I explained" effort to muddy the history of the thread:
    You had not explained that you "backed into the slot" until post #14, and even in that post you still did not say whether you were trying to drive forward or reverse from that position later, after having been asked that specific question numerous times.
    While "backed up to a shop door" would clearly imply driving away forward if it was a closed door, it's equally clear that a door you could back through far enough for your rear wheels to settle into the door track probably wasn't closed. So whether your next move was forward or reverse from that point was still never answered until post #16.
  5. Paul Gregory
    1,442
    374
    Alberta
    2024 Prius Prime
    XSE
    All I can suggest is that you work on your reading comprehension.
  6. ChapmanF
    17,238
    Anybody who can read the posts in this thread can verify both my reading comprehension and your misdirection.
  7. ASRDogman
    ASRDogman Senior Member
    7,173
    3,758
    Pushing the throttle all the way to the floor would allow enough power to the front wheels
    to allow it to get out of the ditch....
