Going overboard?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by benwray1, Jun 28, 2025.
  1. benwray1
    benwray1 Junior Member
    Olathe, KS
    Hey all, I am doing some maintenance on my Gen 3 Prius IV, with 162K miles on it. The engine bay is super dirty, mostly because of a valve cover gasket leak that I am fixing. Here's a list of what I'm doing:
    1. New Plugs/Coils
    2. Valve Cover Gasket
    3. EGR valve cleaning, Throttle Body cleaning, Intake Manifold and Intake cleaning
    4. EGR cooler/tube cleaning
    5. PCV replacement
    6. Oil Catch Can Install
    7. Fuel injector cleaning - I bought a tool on Amazon to clean them after you remove them.
    8. Struts? - I'm not sure if I need to do this or not. This Prius IV is louder than my other Gen 3 Prius I as far as tire noise.
    9. New weatherstripping/window seals
    10. Sound absorption spray under wheel wells.
    11. Sound absorption panels in doors.
    12. Transmission fluid
    13. Coolant and Inverter Coolant
    None of this is due to poor performance, but I'd like to get the best MPG and have the car last as long as possible. I feel like I may have taken on too many improvements. I'm following some of the other posts in this thread but would appreciate your thougths. Thanks!
    Ben
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,725
    1,762
    Bay Area
    I wouldn’t replace the ignition coils if it’s not bad.
    But everything else seems like good preventative maintenance. You better brush up on how to replace the headgasket for the future.
  3. benwray1
    Olathe, KS
    Thanks! And thanks for all your helpful YouTube Videos!
    NutzAboutBolts likes this.
  4. benwray1
    Olathe, KS
    Would you consider replacing the struts to be preventative?
  5. Grit
    Grit Senior Member
    6,575
    4,228
    Wilkes Land
    Shocked that te standard engine oil and trans fluid replacement was left out.
  6. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    When I did my head gasket job I...
    1. Replaced the engine coils and spark plugs (bought a kit that had both)
    2. Replaced PCV valve
    3. Replaced Head gasket
    4. Replaced Water Pump (will replace again as the water pump I bought isn't running properly)
    5. Replaced Timing chain tensioner gasket
    6. Changed Filter, oil, and coolant
    7. power washed the egr, timing chain cover, and intake manifold and cleaned those parts very well.
    I didn't bother with the fuel injectors as I didn't remove those. The rest of the stuff, honestly sounds like "extra credit" or stretch goals. I do need to replace the weather striping on my car however but struts? Maybe I could do the same. Interested in that fuel injector kit you mentioned however. What did you end up buying?
  7. Mendel Leisk
    41,850
    First cleaning?
  8. benwray1
    Olathe, KS
    Yes I will do those too. I forgot to write them down.
  9. benwray1
    Olathe, KS
    Yes, I bought it with about 150 K. And it's pretty dirty.
  10. bisco
    52,337
    do you get your parts from olathe toyota?
  11. NutzAboutBolts
    1,725
    1,762
    Bay Area
    not if it’s not leaking or showing damage.
    adrtho4 likes this.
  12. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    Pretty much my reasoning. If it isn't leaking or showing drainage then no need to replace. valve cover, intake gaskets and such that you get with a gasket kit... yeah. But other stuff...
  13. benwray1
    Olathe, KS
    Update: I started after church today and bought another set of valve cover grommets because the other ones were too hard to install so I ended up destroying them in the process. I got the valve cover reinstalled, power washed all of the removable parts from the engine, removed the fuel injectors and cleaned them with this Autool tool from Amazon.
    It't not available any longer, but it basically hooks up to a battery to keep the injector open, and has a plastic nozzle that fits the end of the injector. Then you remove the spray nozzle from a can of brake cleaner, and shoot it through the injector to clean it out. They were pretty dirty so I'm glad I did it. But I was also covered in brake cleaner when I was done haha! The tool is just about worth the $12 I paid for it three years ago haha! I got the fuel rail and injectors put back on after cleaning.
    I'm getting ready to work on putting the EGR cooler, valve and intake manifold back on, then maybe finish the catch can today. Still not sure if I'm going to replace the struts. I don't think they are leaking, just have torn boots, and 165K miles on them. I also replaced the PCV valve.
  14. benwray1
    Olathe, KS
    No, just Advance, Amazon, and Autozone. If I did the water pump or actually replaced the EGR valve, I might consider that. I didn't want to go through the process of reprogramming the computer so I opted just to clean my EGR valve.
  15. NutzAboutBolts
    1,725
    1,762
    Bay Area
    those gaskets are under heat, so eventually they will crack and need replacing, if it came in a kit, might as well do it since you already have it out and ready to be replace. That’s my reasoning.
    ASRDogman likes this.
  16. adrtho4
    adrtho4 Member
    59
    25
    Houston, TX
    Oh no man I'm with you. I'm referring to struts, sound absorption and other stuff that the op mentioned. I should have clarified. Things that came with the gasket kit absolutely replace.
  17. benwray1
    Olathe, KS
    There is not much room for my oil catch can. I'm wondering if I should have bought a smaller one.
    That's the one I got. I think I may just secure it with zipties to avoid drilling holes in the metal over there by the headlight on the drivers side.
  18. ASRDogman
    ASRDogman Senior Member
    7,788
    3,975
    If you feel the car is driving smoothly and not bouncing when going over bumps, you can
    skip the struts. At least for now.
    Did you put the hose on the exit/nozzle of the injector to back flush it?
    NutzAboutBolts and Grit like this.
  19. NutzAboutBolts
    1,725
    1,762
    Bay Area
    ah ok, 100%
  20. benwray1
    Olathe, KS
    Update: I decided to skip the struts and oil catch can. I began reassembling everything last night (also explaining to my wife why I took my car apart and put it back together haha). I can't seem to figure out the routing of a few hoses and electrical connectors. Because I had the valve cover off, EGR assembly off, along with all the other things that go along with this repair, it looks like some of my hoses walked away, and I have a smaller coolant hose that I can't figure out where to put. I'm going to look back on some videos today to make sure I have everything plugged in right - PCV, air hoses, coolant hoses, etc. If you all have some good photos or tips, please send them my way, and thanks!
