Getting conflicting answers on google about how much oil is needed to do an oil change.
Discussion in 'Gen 3 Prius Technical Discussion' started by h1ph0panonymous, Jun 20, 2025.
  1. h1ph0panonymous
    258
    36
    Definitely will, I have a theory they are charging me for having to open a box of 6 individual quarts and charging me for the 6th quart because “what are we going to do with a spare quart” and the fact they order them by the box of 6, still a stealership kind of thing to do to put the burden of not having 5qt bottles ordered onto me.
    Grit likes this.
  2. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    :ROFLMAO:(y)
  3. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Exceptions doesn’t become the rule.
  4. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    That must have been in the 1970s when last checked so that conclusive.
  5. Paul Gregory
    Paul Gregory Senior Member
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    When you think about it, the Prius engine doesn't work very hard and uses premium synthetic oil.
    Why should it wear out and burn oil?
  6. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    If you managed to wear out a Prius engine, I think you may be the exception to the rule.
  7. PriusTech
    PriusTech Active Member
    253
    112
    Reno
    I think their cheaper filters still have them. Dont care, dont trust them
  8. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    I'm not very anal about exact ounces of oil capacity. Since I switched to using full synthetic about 30 years ago, I haven't had an engine wear out or burn oil, and a few have made it past 300,000.
  9. bisco
    52,219
    i just took it to the local gas station for oil changes, and drain the excess upon returning home
  10. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    What do you consider "excess?"
    And how often does this happen to you?
  11. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    I'm old enough to have had hundreds of oil changes,
    I never heard of any engine damage from over filling.
  12. Mendel Leisk
    41,776
    Geez Paul, you're stamping out all dissension this morning, lol.
  13. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    Your mileage may vary.
  14. BiomedO1
    3,962
    2,089
    SacTown, Ca
    I was kidding. The V6 Camry took 6 - 6.5 quarts and all 4 cylinder Camry's took 4-4.5 quarts.
    The 2.7L Tacoma's took about 6 quarts as well as their V6 cousins......
    Hope this clears things up....
    h1ph0panonymous likes this.
  15. Noahdoge
    Noahdoge Active Member
    210
    147
    Mississippi
    Majority if not all dealerships use bulk oil contrary to what your receipt says.
    h1ph0panonymous and Brian1954 like this.
  16. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    I don't do oil changes at oil change shops any more, since an experience I had.
    There was only one filler hose in the guy's hand when he asked me which oil I wanted.
    I'm sure I could have told him anything, and he would have pretended to be using that oil.
    I think they order cheap oil in bulk from a place called "Service Station Supply."
    The oil they sell is reject oil and dangerous for your engine.
  17. bisco
    52,219
    quarter to a half inch. 19 oil changes over 19 years, including the 2 freebies at the dealers
  18. bisco
    52,219
    just because you haven't heard of it doesn't mean it hasn't happened
    Grit likes this.
  19. Paul Gregory
    2,204
    581
    Alberta
    2024 Prius Prime
    XSE
    I have seen it happen, but it was caused by an idiot we hired who filled the engine with oil right to the top of the valve cover filler. We had up to 30 engines on our farm, which all needed periodic oil changes and a few of them got overfilled. Not one of them were ever damaged as I recall.
  20. h1ph0panonymous
    258
    36
    Bulk as in like this? Because I throw away about 20 of these boxes every Sunday at the Dodge/Kia/Chevy Dealership I clean floors at and do mechanics trash on Sundays.
    #60 h1ph0panonymous, Jun 29, 2025
