EMERGENCY: Inspection at end of month and sensors not being available/supported/detected
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Anon Adderlan, Jun 27, 2025.
  1. Anon Adderlan
    Anon Adderlan Junior Member
    Syosset, NY
    The inspection for my 2004 Prius is coming up at the end of the month, and the EGR System, Oxygen Heater Sensor, Secondary Air System, and Heated catalyst are STILL not being detected. Not failed, not detected AT ALL. I’m told that’s normal for some of these systems as they’re not present, except for the Oxygen Heater Sensor. So regardless I need to at least know the reasons that sensor is coming back as ‘unavailable’ rather than ‘failed’ or flagging any codes specific to it.
    I am absolutely desperate at this point. If I lose the car I will not only be without a home once the town demolishes it next month, but without a car as well, which leaves me with nothing.
  2. Tombukt2
    12,924
    2,322
    In upstate NY? So you're doing this by looking at the IM monitors on a scanner correct? I think that's a bit different . How do you know which are sposed to be detected and not ? I know I don't know this and I lived in many emissions States. Back in the days when they shoved the thing up your tailpipe and number showed on the screen and if they weren't in green you didn't go . But they're was always a way around . Referee get it put off till next year n such . As long as there wasn't sheet metal hanging off your car and general things like that going on car looked presentable etc there was a work around of some sort . I cannot imagine this is still no so
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,040
    1,967
    NJ-USA
    I do not have an "early" Gen 2 (2004-2005). They have somewhat different emissions systems than my 2006.
    Either your car does not have the oxygen sensor heater monitor, OR your scantool is not correctly reporting the results from the car's ECM.
    If you have access to a different tool, you might try that. In general, as long as you do not have codes that trigger the "check engine light" and most monitors are "ready", you should be ok.
    Most states permit 1 monitor to be not ready.
  4. BiomedO1
    3,550
    1,839
    SacTown, Ca
    If you disconnected the battery, in order to erase the CEL - those sensors won't read for about 50-100 miles. The ECU is trying to recalibrate and determine if there's a fault. If a sensor is faulty (ie: O2 sensor heater) it'll pretty much trigger right away.
    Hope this helps....
    FWIW: most honest shops will tell you to just drive the car around until all the sensors become 'ready'. The dishonest ones will simply bill and fail you, then offer to fix it - drive it around for you......
  5. mr_guy_mann
    4,040
    1,967
    NJ-USA
    It depends. In many states an inspection facility MUST test the car "as presented". Sounds stupid but that's the letter of the law. The shop can get fined or penalized for doing anything else.
    It's up to the car owner to make sure that everything is ready for inspection.
