Buying a 2019 Gen4 w damaged body strut - concern?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PaulyG, Jun 29, 2025.
  1. PaulyG
    PaulyG New Member
    Tucson
    2019 Prius
    Close to buying a Gen4 Limited (refresh/ facelift) but the garage check shows damage to a front right piece of the chassis/core. Its clearly hit something a while ago, and gotten bent back, but still looks intact/ strong (AZ car, no rust or corrosion) Seems to be an older event, and I suspect current owner has been driving w it like that for a good while.
    I will negotiate a price to take it into account, but: is this a deal breaker or easy fix, or don't worry about it?
    Needs new front floor pans of course, but thats kinda easy.
    #1 PaulyG, Jun 29, 2025
  2. PaulyG
    PaulyG New Member
    Tucson
    2019 Prius
    Try that again:
  3. bisco
    51,969
    anything on the carfax?
  4. PaulyG
    PaulyG New Member
    Tucson
    2019 Prius
    Nope. Carfax is clean other than some hail damage repair to the hood last year.
    Thanks for suggesting checking tho!
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Prius is a low clearance vehicle. You're going to hit things on the highway. Wife hit a piece of metal that scared the sh*t out of her. She only saw it in her rear view after running over it. Resulted in the hood latch misalignment such that it won't release normally anymore. It stays securely closed, but won't release completely with the control inside the car. It unlatches, but doesn't "spring up" anymore.
    #5 FuelMiser, Jun 30, 2025
  6. PaulyG
    PaulyG New Member
    Tucson
    2019 Prius
    Thanks. I am inclined it's something to live with, IF the price is right.
    Car does not pull in any way. No abnormal tire wear of whatever. It's bent out of shape, but not broken.
    They are taking it to main Toyota dealer body shop here in AZ, who of course will want to repair for $$$, but lets see.
    Or... we can 'pass' and continue looking for another model.
    Clearly someone has hit something hard in the past, but there's nothing on Carfax.
    (as everyone knows, going offroad in a Prius does not work!)
