Affordable Combi Meter Fix in NJ?
Discussion in 'Gen 2 Prius Main Forum' started by Bechi, Jun 30, 2025.
  1. Bechi
    Bechi Junior Member
    37
    US East Coast
    2025 Prius
    Limited AWD-e
    I've had the black instrument panel combination meter failure about 4-5 times now over the past few years and I know it's going to eventually fail completely. I'm at 18 years and 340K (original owner).
    Would anyone know of a place in NJ that would be willing to fix this for me at an affordable price? I haven't gotten a quote from my stealership, but have heard that many are asking for thousands. This is not something I can attempt, especially considering my lack of patience <g>.
    Thanks!
    Bechi
  2. Tombukt2
    13,484
    2,425
    Get a board out of another car it's going to be your cheapest option. Not all of them in the world are broken . Whilst that one in hand they're a million videos how to go about it. But ya should get a junk part before disabling you're car and so on.playibg with ground wire under twilight can revive door open sign and display very quickly and keeping car alive never lets it go dark . But it's too many instructions to keep up with .
  3. bisco
    52,417
    it is unlikely any pro will do it for cheap, it is a big job. anyone should be cheaper than a dealer though.
  4. fragglestickcar
    92
    49
    New York
    Well, in the grand scheme, it's quite a small job, and someone who's practiced could probably turn it around in less than an hour. The dealership won't attempt to replace the cap and will purchase and program a new board which is super expensive. Keeping the board and replacing the cap is close to 100% reliable but I agree even smalltime fixers will probably charge a couple hundred. We all need to eat.
  5. Bechi
    Bechi Junior Member
    37
    US East Coast
    2025 Prius
    Limited AWD-e
    Thanks, fragglestickcar. Hoping someone might know of a place that can do it for less than four figures. Less than $500 and I'll be very happy!
  6. qmanqman
    qmanqman Active Member
    439
    152
    CO
  7. Bechi
    Bechi Junior Member
    37
    US East Coast
    2025 Prius
    Limited AWD-e
    Nuh uh. I know there are a bunch of videos out there and a bazillion threads on how to DIY this, and from looking at these, I know I definitely do NOT have the patience to fiddle around with the dash to do this myself! Thank you, but I know better! <g>
    bisco and fragglestickcar like this.
  8. bisco
    52,417
    knowing our own limitations is important, and helps to keep us out of trouble
  9. BiomedO1
    4,220
    2,204
    SacTown, Ca
    When you find someone to do this repair; make sure you do a real good inspection of their work - after it's finished. On a car that old, a lot of the dash board plastic is going to be very brittle and will break easily. Place your nails between the plastic seams they need to remove and give them a gentle tug. If they pop out, the retaining tabs are busted and will probably pop-off when you go over a bump.
