Further hybrid system testing and help needed.
Discussion in 'Gen 3 Prius Main Forum' started by Prius92, Jun 28, 2025 at 1:31 PM.
  1. Prius92
    Prius92 Active Member
    521
    112
    Iowa
    The battery isn't weak tho, it measures fine.
    The temps are not going down and past these temps the charge capacity is reduced. Between 77F and 107F, the max charge is 33.5HP.
    Around 118F, the max charge is 24.1HP.
    If you can't get the battery below 107 degrees, the amount of juice allowed to go into it and out of it, is reduced.
    So you think you have a "weak" battery, but this weakness is imposed by the computer in the hybrid battery in order to keep it from getting even hotter and reducing it's lifespan.
    If you don't have as much power to spare due to this limitation, then the ICE works more, and consumes more gas.
  2. ASRDogman
    ASRDogman Senior Member
    7,192
    3,766
    Maybe the space between the blocks are clogged. Since the fan looks like that, it only makes
    sense that the battery space is full of that also.
    Pull the cover off, and clean! Check all the connectors on the blocks....
  3. Prius92
    521
    112
    Iowa
    Do you have a link to your vent tube cooler? Someone mentioned that in another thread.
  4. ASRDogman
    7,192
    3,766
    If the space between the blocks are blocked so air cannot flow to cool them, it doesn't matter how cold the
    air is going in.
    You should treat the reason for the issue, not the symptom...
  5. Brian1954
    Brian1954 Senior Member
    1,750
    682
    South Central PA, USA
    Can you please answer the question about your hybrid battery asked in post #14?
    Please give a history of any work or module replacements that you have done on the hybrid battery.
    Is this your 2008 Prius? How many miles on the car?
    How have you determined that the battery isn't weak? What measurements have you done?
    #25 Brian1954, Jul 1, 2025 at 11:05 PM
  6. Grit
    Grit Senior Member
    6,443
    4,184
    Wilkes Land
    There is not vent hose on a Prius. A vent hose are for AC exhaust and laundry drier applications. M
  7. ChapmanF
    17,264
    My 2010 doesn't have a vent hose.
    It has two vent hoses.
  8. Prius92
    521
    112
    Iowa
    It was reconditioned 2 years ago. Weak cells replaced as well.
    I just did a capacity test this morning and it's 72% of factory capacity, which is good considering these are original Gen2 cells and are approaching 20 years old.
    I've seen 2015's with 100k miles have similar percentages.
    197k miles on the car.
  9. Brian1954
    1,750
    682
    Did you use the Dr Prius app or something else to do this measurement?
  10. Prius92
    521
    112
    Iowa
    Dr Prius.
    Brian1954 likes this.
