Prime charging slow
Discussion in 'Prime Plug-in Charging' started by Alfonso2000, Jul 2, 2025.
  1. Alfonso2000
    Alfonso2000 New Member
    New to me 2021 Prius Prime XLE
    Plug in 110 charger says/takes 8.5 hrs (should be 5.5)
    New 220 charger says/takes 5 hrs (should be 2)
    Otherwise running great and gets full 25mi on charge.
    What to do???
    Thanks
  2. primeobjective
    primeobjective Junior Member
    Beaverton, OR
    2022 Prius Prime
    Go into your vehicle settings on the dash touchscreen and see what charge current is selected. There's an 8A and 16A setting (and maybe a max setting). Sounds like a lower charge setting is selected. We charge our Gen4 at 8A/120VAC to be as gentle on the battery as possible.
    pasta4breakfast and BiomedO1 like this.
  3. bisco
    52,324
    'says it takes'? have you actually tried charging?
  4. BiomedO1
    4,047
    2,132
    SacTown, Ca
    Someone probably set the car to not exceed 8A while charging. Check your settings
    FWIW; my battery only takes 4.5-5.0 hrs. on 120VAC to recharge for my morning commute.
    pasta4breakfast likes this.
  5. Alfonso2000
    How do you know charging at lower amperage is better for battery?
  6. Alfonso2000
    Found charge settings of "8amp and Max" (16amp I believe)
    Also read several places that lower amp charging is better for long term battery health (less heat), so since this car already has 120k and I'm going "long" on this car I'll keep it at 8amp and bump it up occasionally if needed.
    THANKS
  7. CharlesH
    2,797
    1,164
    Roseville, CA
    The 8 or 16 amp charging from the charger is nothing compared to up to 90 amps of regeneration current every time you step on the brake or coast down a long hill. Discussions here in the past suggest that the difference in battery wear between 8 or 16 amp charging is negligible. The main reason for the 8 amp setting is not for the car; it is for the homeowner who doesn't have 120v circuits in their home that can provide 16 amps for hours; the 16 amp load from the charger would trip the breaker in their home, but 8 amps won't.
  8. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    Alfonso, since you're 'going long', I recommend that you buy a good quality bluetooth OBD2 dongle like the OBDLink MX or LX. Don't buy a cheap adapter - they just don't work. Then use Dr. Prius to check the status of all 95 of the battery cells. I recently posted the results of that test for my 2020 Prime in the Technical Discussion section. What you want to see is when the battery is at --%, i.e. 0% capacity, the cell voltages are tightly clustered. One or two cells that have a significantly lower voltages is a bad sign.
    Once you've got the dongle, you can also use Hybrid Assistant to monitor and record an amazing amount of data while you're driving. The report that you can generate is many pages long. You can also use Tire Assistant to check the tire pressures. It's stupid that you can't do this with the car itself, but that's the way it is.
  9. BiomedO1
    4,047
    2,132
    SacTown, Ca
    The traction battery is under warranty for another 6 years or 30K miles. It's the accumulated heat and lack of use, that destroys the traction pack. The faster you charge it the more heat is generated. If that heat can't be dissipated fast enough, it starts to shave long term life off the pack. Ditto with a pack that's unused for 3+ months at a time; see long term storage of car in OM. That's why the gen5's went to freon based cooling. IMHO; if you adhere to the OM for the traction pack care, you should be OK. There's plenty of gen2 and gen3 with over 200k, still on their original packs.
    2021 Prime has a lithium pack, so Dr Prius is going to give you questionable results if any - since Dr Prius was setup for a NiMH battery pack. I did use that app to turn-off, single beep when I'm in reverse.
  10. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    Dr. Prius states that it supports "1. 2020+ Prius all lineup except 4WD version" and "4. 2016-2019 Prius Gen4 One, Two, Two Eco, Three(Lithium) and Four(Lithium)". The 2024 Prius uses a lithium-ion battery. So the app appears to understand lithium batteries. Do you see any errors or inconsistencies in the data that I posted in the Technical Discussion section? The most likely errors would be incorrect voltages or wrong number of cells but both are correct. 3V4x is an appropriate voltage for a gently discharged lithium-ion cell. Even if some of the program's functions don't work properly, this test only involves reading measurements that the car made and displaying them. Not a very hard job.
  11. BiomedO1
    4,047
    2,132
    SacTown, Ca
    It's posted on the internet so it must be true.....
    If you don't know what your doing, which is the current ops case; How does he know that the program isn't functioning properly, displaying bad information, or something just out of "left field"? The last time I looked at it, it threw some weird numbers at me - but that was 2021. If the app has been updated/fixed - Great..........
  12. Alfonso2000
    Thanks BIO, OM = Owners manual? IMHO = ??. Traction battery is what in a 2021 Prius Prime? Is that different than the hybrid and or EV battery? What is the best way to store this car for 6 months?
  13. bisco
    52,324
    om = owners manual, imho = in my humble opinion, traction battery = hybrid battery or ev battery.
    best way to store the car for 6 months is to drive it until the wall charge is gone, and it is acting like a non plug in hybrid. instructions should be in the owners manual.
    pump up the tyres to max sidewall pressure and put a battery maintainer on the 12 volt battery, or at least disconnect the negative cable.
    consider reading up on rodent problems, they like prius wiring when no one is around, and that can get expensive.
    in all honesty, hybrids weren't really designed for annual long term storage such as a vacation home and etc., they like to be driven.
  14. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    It's posted on the internet by the people who wrote the program, not some random page.
    That's why I posted my results from the same test. They show typical results for a good battery that the OP can compare his results to.
    So since you don't like Dr. Prius for this, what tool/program do you recommend for the OP to check on the health of his traction battery?
  15. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    Notice how much power is provided when in Charge-Mode. That's 7.2 kW, twice as much as when level-2 (240 volts) charging.
  16. pasta4breakfast
    113
    Anaheim, CA
    2020 Prius Prime
    I have only used the 8a setting twice. When I first got the car my apartment complex said that charging it on the standard outlet in the garage would trip the circuit. I thus charged at a L2 charger in a Target parking lot near me. This got really annoying, so I tried charging it at 8a overnight. Nothing bad happened. Eventually I got the courage to charge it on the max setting. I have had no problems ever since. Turns out the appartment complex didn't know what they were talking about. I now see Teslas charging in garages all the time. Presumably they are charging at 120v for much longer than my Prius Prime.
    I also tried using the 8a setting to prolong my charging sessions at work. I would plug the car in on my lunch break and set it to 8a so the battery wouldn't be full for several hours before I drove home. Sometimes I would forget to set it back to max, which got annoying really quick, so I abandoned it. Now the stations get pretty full, so that wouldn't be very considerate anyways. You can also use the charge schedule to accomplish the same thing.
    I haven't seen any real world data showing L2 charging causing more battery degradation than L1 charging. I have only seen data on L3 charging increasing battery degradation in EVs. Thus, I see no benefit of slowing charging below max ampurage at 120v or even 220v.
  17. Danno5060
    Danno5060 Active Member
    393
    201
    Wyoming
    When I first brought my "new to me" 2019 Prime, it was set to max. I've also got a freezer in the garage, which is on the same circuit. Every morning, the 20A breaker for the garage was tripped. I set the charge rate to 8A and it didn't trip the breaker.
    Since then, I ran a 50A 240V circuit to the garage (the maximum for my car is 12A, but I figured it was future-proofing in case I ever got an EV, or wanted to run a welder, or a larger air compressor). I picked up a relatively inexpensive Level 2 charger (one without much programmability, but the car has all the charge scheduling I need). It's also a bonus that my charging times are half of what the 120V ones are, but I gotta sleep sometime.
