Ac blowing warm after water pump install.
Discussion in 'Gen 3 Prius Technical Discussion' started by CurtisGreen, Jul 2, 2025.
  1. CurtisGreen
    CurtisGreen Junior Member
    NoVA
    I replaced the water pump and thermostat. Stupidly, when I took the connector for the AC compressor out, I didn't cover it with plastic. So, when I disconnected the hose from the thermostat housing it filled the ac compressor connector socket with coolant. I blew it out with a can of air and it looked dry. I got everything put back together and went to start the car. The AC was blowing hot and the Check Hybrid system message came on. Would the coolant spilling into that connector socket be enough to kill the compressor? Is there a way to test the compressor to see if it's dead? Could I have caused a leak in the AC lines by knocking into them while removing bolts from the water pump?
  2. CurtisGreen
    NoVA
    This was the pressure. Was the same with car on and AC on and when the car was off.
  3. Tombukt2
    13,686
    2,478
    That's right no hi and lo sides exist until compressor is on .
  4. BiomedO1
    4,381
    2,303
    Left Coast
    The AC pressure sensor switch is in that general area. Perhaps you knocked it loose or broke a wire????
    CurtisGreen likes this.
  5. CurtisGreen
    NoVA
    If i had knocked it loose or broke a wire would it throw a code? I currently have no codes. The car drives fine. I have taken it on short trips to the store. There is refrigerant in the system. I just don't have AC. it blows warm.
  6. Mendel Leisk
    42,097
    There could be codes associated with that.
    How about the high voltage (orange) connector to the compressor: any chance it's not in place.
  7. Brian1954
    Brian1954 Senior Member
    2,524
    1,006
    South Central PA, USA
    If you have the "Check Hybrid System" message, there are trouble code(s) that need to be read with a capable scanner. Reading the trouble codes is the first thing that you need to do.
    If the scanner that you are using can not read any trouble codes, then you need a better scanner. Read post #1 and then scroll down to post #37 in this thread, https://priuschat.com/index.php?posts/3246758
    #7 Brian1954, Jul 3, 2025
  8. BiomedO1
    4,381
    2,303
    Left Coast
    Unknown because it's not a critical operational component. Your compressor isn't running, because the high and low side pressure is equal. One of the things the AC system will check before enabling the compressor is freon pressure. No or low freon pressure, no compressor actuation.
    Hope this helps....
  9. ASRDogman
    ASRDogman Senior Member
    7,933
    4,039
    The smart thing to do is to check everything.
    The pressure does equalize, that is normal when it is off.
    You may have shorted out the connector for the compressor. Did you check the fuse?
    You should spray out the wire connector with brake cleaner, and also the connector
    on the compressor. If you have compressed are, blow both connector/connection to clear it out.
  10. CurtisGreen
    NoVA
    Oh ok, i have a cheap scanner. I ordered a bluetooth one and will use drprius app to read the codes, Thanks!
    Thanks. I have ordered a scanner that will be able to pick up the hv system codes. i didnt have brake clean on hand but used compressed air and blew the socket out until it was completely dry before connecting the connector back in. I did check the 10 amp fuse in the box under the dash and it was good. I guess at this point im just waiting for the bluetooth obd 2 connector. Is the fact that there is pressure on both sides a sign of there not being a leak that was caused during the water pump replacement or would that still be a possibility?
    I will check the connector but i dont think i would have knocked it loose. I have ordered a bluetooth obd 2 dongle that will let me check hv system codes. Will get back when i see what they are. Thanks for the reply
    #10 CurtisGreen, Jul 3, 2025
  11. ChapmanF
    18,801
    There can be a lot of things to check. Generally, though, when there are things the car is telling you to check, it will often be worthwhile to check those things first. That's the point of reading the trouble codes that go with your Check Hybrid System message. The A/C compressor gets its power from the hybrid system and there can definitely be codes related to it.
    Brian1954 likes this.
  12. CurtisGreen
    NoVA
    yes i will scan the codes. w/e the issue is, its related to me changing the water pump. The only thing that didnt go smooth with that was the coolant getting into the connector socket on the compressor and now my a/c doesnt work. hoping i can just swap the compressor and fix the problem. Will find out more when my bluetooth obd 2 dongle comes in
  13. Brian1954
    2,524
    1,006
    The Dr Prius app is good for looking at the hybrid battery. It is not capable of reading all the trouble codes in the Hybrid Vehicle Control Sytem. A better choice would have been a scanner that is capable of communicating with all the ECUs (systems) in the car like the Autel AP200.
  14. ChapmanF
    18,801
  15. CurtisGreen
    NoVA
    thank you for the resource!
  16. CurtisGreen
    NoVA
    will that be different than this?
    Panlong OBD2 Scanner Bluetooth OBDII Diagnostic Tool Car Code Reader Turn Off Check Engine Light Support Android Torque App
  17. Brian1954
    2,524
    1,006
    Yes. The Autel AP200 is a Bluetooth OBD2 dongle, and you use the Autel app with it. You can not use the Autel dongle with your other apps, so it will not work with the Dr Prius app.
    The Autel AP200 is available on Amazon. The dongle is white in color.
    The Panlong OBD2 Bluetooth dongle can be used with a number of different apps. The Dr Prius app is one of many.
    #17 Brian1954, Jul 4, 2025
  18. CurtisGreen
    NoVA
    My dongle came in and i pulled the code
    P0AA6. I dont think i need to pull a sub code since the AC cut out at the same time the code was caused and i filled the ac compressor connector socket with coolant. Also coolant sprayed from the thermostat housing all over the high voltage connection point from the ac compressor. I will drive for a day with the AC turned off. if the hv battery light doesnt come back on then that will confirm the compressor.
  19. ChapmanF
    18,801
    As you've just learned, that isn't an "hv battery light", it's a general "problem with the hybrid system" light. :)
    Brian1954 and BiomedO1 like this.
  20. Brian1954
    2,524
    1,006
    Which Bluetooth dongle did you buy, and what app are you using? If you are using the Dr Prius app, it will not give you the INF (sub-code), but the Autel AP200 will.
