Sodium ion hybrid battery bad already?
Discussion in 'Newbie Forum' started by Nightfoxx, Mar 11, 2025.
  1. Iron Man Prius
    Iron Man Prius Junior Member
    98
    25
    Fullerton
    Three Touring
    Sodium Ion's haven't been on the market for public sale that long.
    Someone mentioned 2 winters testing, yes those are the beta test cars with different versions of the sodium (Winter 2023 and Winter 2024) yes?
    #21 Iron Man Prius, Jul 3, 2025
  2. mudder
    mudder Active Member
    250
    327
    Chattanooga, TN
    You are correct that the sodium cells in NexPower's beta test packs were different from the production version. However, this is a moot point, as I'm still not convinced the beta packs were actually tested through Winter2023. If I'm correct, then the beta and production cells have the same cold weather testing (i.e. only Winter2024). NexPower's silence is a telling answer.
  3. Iron Man Prius
    98
    25
    Fullerton
    Three Touring
    Inside sources told me that he was already testing the beta Sodium's already towards the end of the V2 not even 2.5 Lithium. Not sure why the source would exagerate the timeline as Jack has always been an innovator and working on things WAY in advance of public knowledge to keep the edge on propriety.
