Car won't start - replaced 12v battery to no effect
Discussion in 'Gen 2 Prius Main Forum' started by Trynafixmyprius, Jul 2, 2025.
  1. Trynafixmyprius
    Trynafixmyprius New Member
    Hi all, I arrived home yesterday after a ~20 minute drive, turned off the car for 5 minutes and came back out to go to the grocery store. When I tried to start it, nothing happened. There are lights on in the car, the open door chime plays when I insert the fob into the dash and open the door, but there is zero reaction to the start button being pressed.
    Over the last few days, it has been slightly sluggish in starting so I figured the reason it wasn't starting now was a bad 12v battery. I called a guy out to replace the battery but the car still didn't start after he put a new one in. He did some voltage testing, checked a few fuses, and ended up coming to the conclusion that it was the fusible link that was the culprit (this part -
    ) . The main reason he thought this was because there was less than 1 volt of charge at the jumping point, right where that part is.
    He suggested I buy that part and try to replace it myself but I figure whatever messed up the fusible link in the first place would probably just happen to the replacement as well. Just wondering if anyone has any experience with anything like this
  2. pasadena_commut
    pasadena_commut Senior Member
    2,722
    813
    Southern California
    Check the AM2 fuse. When the inverter pump goes it can blow the AM2 fuse then the car won't start. If that fuse is bad there is a connector to detach if you want to limp the car around without that pump, until the pump is replaced. As long as it is reasonably cool (<70F?) the Prius will run OK without the pump so long as it isn't asked to do something extreme, like climb a long hill. I suppose it is possible that the fusible link also blew, but pretty sure the design is that the AM2 fuse protects the fusible link. Search this forum for pictures and more information.
  3. Trynafixmyprius
    So when the guy was there I did actually have him pull the AM2 fuse out and test it and there wasn't an issue. That was the first suggestion I saw online when I started searching around about this issue so it was one of the things we made sure to check.
  4. PriuSocal
    PriuSocal Member
    248
    47
    SoCal
    Perhaps not your issue but it’s worth checking. I recently had a similar alarm works, chimes but no start or action from the car afterward. I also tried pressing the key button on the kick panel under your steering wheel and nothing. I had detailed the car from the inside and one of the things I removed was the center console (part where your lay your forearm) and did NOT connect the connectors behind the center console and turns out that one of those connectors goes to the Key Proximity Sensor. This sensor is what detects whether or not your key is on you or nearby to start the car (this is assuming your prius has the smart key option). I reconnected that and the car started immediately.
  5. rogerthat
    rogerthat Active Member
    391
    124
    Georgia
    Who did you call to replace the battery? What 12V was used for the replacement?
  6. Mendel Leisk
    41,698
    The car won't start unless you depress the brake pedal. There's a sensor at that pedal to verify it's depressed: that might be out of adjustment.
  7. Trynafixmyprius
    I will check this today, as well as the key fob related fix mentioned above. The reason I thought it was battery related was because the failure to start was preceded by sluggishness to start but perhaps that was the sensor or wire slowly working its way out of place or something
    I was hoping to get the car back in the road the same day and I'm not overly handy so I called a very well reviewed local guy, I believe the battery that was put in was an Interstate AGM Battery, S46B24R
