Auto parts store cleared codes now :(
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tom B., Jul 6, 2025.
  1. Tom B.
    Tom B. New Member
    Il
    First of all hi and thanks for any further help .
    so here is how the story goes this is not my car it’s my parents who are in their mid 80’s it needed some strut work so they parked it over the winter . Until I could get time to change out the struts . When I went to work on it the 12 volt battery was dead(2 volts dead). I charged the battery till the battery charge shut [email protected]
    I reinstalled the battery started and moved the car to garage and did the strut change everything went fine took it out for a ride around the county block 5 plus miles every was great brought it back parked it in the garage next day my dad went to take the car out it would not start so they took the other car.
    When I checked the 12 battery it was dead it showed 11 volt but only 6volts under a load so I took the battery out told they to get a new battery . The dead battery triggered lights on the dash.
    My dad installed the new battery and the car ran fine other the the lights on on the dash.They dove the car I would guess about another 50 miles here and there doing this and that ( getting it lined ect ect).
    Then they were going to bigger town to do some shopping being my dad the lights bugged him .He stop in a the local town to the big box auto store to have them check for codes which they did and cleared without giving him any kind of printout.
    After they cleared them codes the car will not accelerate the car only runs about 6~8 mph it seems to be running on battery power when the gas engine should start the car shutters and just slows down to the 6~8 speed and is only running on the high voltage battery .Which kinda baffles me because when it back it out of the garage the gas engine starts and runs.
    I have a cheap obs2 scanner and it only shows to codes P0441&P0445
    I found a fairly large hole in the vacuum line to the pcv valve and I’m pretty sure the gas cap is bad..the vacuum line is fixed and a new oem Toyota cap is coming this week. The car has approximately 120k on it
    I’ve tried searching the forums for days similar problems with little luck on my part I’m sure its on here somewhere if I only knew what I’m looking for
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,725
    1,762
    Bay Area
    So after the fix, did the car drive normally?
  3. bisco
    52,348
    you need to read the trouble codes
    Danno5060 and Brian1954 like this.
  4. NutzAboutBolts
    1,725
    1,762
    Bay Area
    he got the trouble codes, has to do with his EGR and EVAP system due to the vacuum hose leak and possible gas cap?
  5. bisco
    52,348
    thanks, i missed that. if those don't clear it up, he may need a better scanner
    NutzAboutBolts likes this.
  6. NutzAboutBolts
    1,725
    1,762
    Bay Area
    I think those are his issues currently so the codes will stay, unless he fixes the issue… no update yet so who knows :whistle:
  7. Tom B.
    Tom B. New Member
    Il
    The fix as in the vacuum hose on the purge valve (I know I said pvc but it was the purge valve)and the vacuum hose … the answer is no the gas cap is just now sitting front of me it just came in and I just got home.. I don’t think the gas cap would keep the engine from starting when driving
    It’s not that cheap of scanner it should be able to do something it has quite a few functions including live data
    to be honest me not fully understanding the full functions is most likely more the issue than the scanner
    #7 Tom B., Jul 7, 2025
  8. Tom B.
    Tom B. New Member
    Il
    Vacuum hose and gas cap made no difference in the gas motor starting when driving.
    rescanned the car 21 module memory (8dts)
    Engine and ect (2)
    P0441
    P0455
    Smart key(3)
    B2784 antenna coil open/short ( 2 times)
    U0155 lost communication with instrument panel cluster
    Tire pressure monitor (3)
    Transmitter id2 not received
    Transmitter Id 4 not received
    C2175 vehicle speed or rissi signal error
    When I switched to ev mode it said “ ev mode not available “
    When I ran the hybrid battery scanner it shows all 14 cells @15.5 or 15.6
    Power mode made no difference in trying to accelerate
  9. NutzAboutBolts
    1,725
    1,762
    Bay Area
    Looks like more issues than just the 2 codes you posted…
    time to start fixing those codes
  10. Tom B.
    Tom B. New Member
    Il
    The evap codes should be fixed..they are in the permanent dts and the car hasn’t ran long enough to clear
    The B2784 antenna coil open/short ( 2 times) I do need to check
    The U0155 lost communication with instrument panel cluster (is most likely caused by the dead battery issue)
    And the 3 tire pressure codes which 2 of are most likely dead batteries the third is still a tire pressure issue
    I don’t mind fixing problems but I’m not going to fix all the minor dts to find out it’s a 2k traction battery
    The car ran great even with the idiot lights on until the auto parts store cleared the codes. In town speeds and highway speeds were fine good acceleration after they cleared the codes 6 to 8 mph tops .My dad knew as soon as he left the parking lot that instant it was not right . 60 mph to town and 6 mph after clearing the codes… come on
    It feels like it has a slight shutter when the engine try’s to start
    I do not want to start throwing the parts cannon at this thing to only spend a ton of money on to only find out it’s not worth fixing .. That being said I don’t really think it’s much wrong with it… as it was a simple( or should have been a simple code clearing that caused all this) mess
  11. Brian1954
    Brian1954 Senior Member
    2,387
    959
    South Central PA, USA
    Which vacuum hose on the purge valve had the leakage. The one between the purge valve and intake manifold or the other one that connects to a steel pipe near the EGR valve. Both of those vacuum hoses deteriorate over time and need to be replaced when they get to be about 13 to 14 years old.
    Based on the P0441 and P0455 codes, you still have a vacuum hose leak somewhere.
  12. Danno5060
    Danno5060 Active Member
    394
    201
    Wyoming
    Unless it's a plug in version, that's the normal response to switching to EV mode. There are a lot of limitations, including that the ICE engine must be completely warmed up, or so many other limitations that the EV mode is useless.
    The Power mode doesn't change the thing into a rocket (nor does the ECO mode all that much). The change is more subtle. It's more like a slight adjustment to the throttle response to the accelerator pedal. This is also overridden when you're pressing the gas pedal more. If you're not the normal driver of the car, and even if you are, it's doubtful you'll be able to tell that much. Maybe just that the car is more likely to be running the ICE engine.
    The loss of communication sounds like it's a serious issue, but maybe it's a holdover from when the accessory battery was low. When that happens, the car enters a mode where the various computers repeatedly crash and restart. I hate to say it, but maybe clear those codes and see if they come back. The usual suspects for communications issues are blown fuses powering the ECUs, corrosion in the wires and connectors powering the ECUs, corrosion in the communication wires and connectors between the ECUs, and corroded grounds.
    #12 Danno5060, Jul 8, 2025
  13. Tom B.
    Tom B. New Member
    Il
    Hi Brian I was visually looking over the hoses and first found the hole/split in the hose between the purge valve and intake manifold and replace and clamped both ends of the hose with worm type hose clamps then started looking at the other one and seen small cracks on both ends of that hose before I replaced that hose I hooked up a homemade smoke machine and pumped smoke till it had smoke coming out of the gas tank vent valve. While my dad kept pumping I looked for smoke along the pipes and the charcoal canister and even toward the top of the gas tank to see as much as possible with out having to drop the tank down to see more.
    Then after the smoke test I replaced the one that goes on the steel pipe with a new hose and worm style hose clamps on both ends I don’t think there is a leak but I will say nothing is impossible if there is a leak I don’t think it keep the car from running ( because it runs fine in reverse in it should be good enough to run in forward even if it’s not 100% leak free)
    The has car has probably only been driven 500 ft or less so I’m more that sure that’s not enough to clear the permanent code and it doesn’t show up as a current code it’s a permanent code
    The new hoses and oem Toyota gas cap have not helped on the no start of the gas engine while driving forward down the road but when I ready the car and back out of the garage the gas engine starts and runs fine in reverse in forward and 6 to 8 mph you can feel the car shutter and slow down and when you left off the pedal because you can feel it’s not right the battery driving takes over and you are in that 6 to 8 mph range running on the battery
    the tire codes shouldn’t keep it from running so at this point I’m not doing anything with( I know the batteries are dead)
    The antenna codes and communication code I have yet to have a chance to look into I do think is a dead battery issue code on the communications is just that from the dead battery
  14. Tom B.
    Tom B. New Member
    Il
    I just wanted to try the different modes to see if it made any difference in the starting is/ was all
    I checked all the blade type fuses in the fuse box in the engine bay with a test light I need to test the block type fuses and relays I guess are there any other fuse box’s else where?
  15. Brian1954
    2,387
    959
    There is a fuse box inside the car, driver's side near the parking brake.
