How long does the original hybrid battery last?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by steve0826, Jul 8, 2025.
  1. steve0826
    steve0826 Junior Member
    30
    Bellevue, WA
    My 2004 Prius is still on its original hybrid battery. Average 46 MPG.
    PriusCamper likes this.
  2. Brian1954
    Brian1954 Senior Member
    1,862
    734
    South Central PA, USA
    The hybrid battery usually lasts about 12 to 18 years. Hotter environments will be shorter. Cooler environments will be longer.
    How many miles on your car?
  3. Moving Right Along
    Moving Right Along Senior Member
    703
    548
    It’s hard to say exactly how long the traction battery will last. A few years ago, I compiled as much information as I could from forum posts, Consumer Reports, and articles I could find, and the results showed there is a very small chance (approximately half of 1%) that a Prius traction battery will fail within the first 10 years, followed by a 3% chance of failure each year after that. Median distance driven at traction battery replacement was roughly 150,000 miles. Most likely, the odds of battery failure go up exponentially after some point, but there just aren’t enough cars still left on the road after 15 years and 200,000 miles to know for sure.
    I can say that a Toyota spokesman described that the designed life of the car was 180,000 miles and the battery was intended to last for the life of the car. So a 2004 Prius likely has gone beyond the original design life of the car. My 2009 Prius with 195,000 miles has also gone beyond that design life and also has the original traction battery. That probably means that nobody really knows how long the traction battery in your car will last. It could start failing tomorrow, and it could last another 5 years. But knowing that it’s gone beyond it’s original design life, it would probably be a good idea to start saving up for a newer car for whenever that might be needed.
    saneesh8 likes this.
  4. bisco
    51,247
    In dog years?
  5. steve0826
    30
    Bellevue, WA
    My 2004 Prius has 183K miles.
  6. BiomedO1
    2,867
    1,529
    SacTown, Ca
    letting the car sit idle (storage) for several months at a time will also contribute to the traction batteries demise.
  7. bisco
    51,247
    under the right circumstances, they last the life of the car
  8. steve0826
    30
    Bellevue, WA
    Yes, you are correct. My plan on if hybrid battery die is this:
    Option one: replace it with recycle battery. I know a place near me and it will cost $1K.
    Option two: get the gen 5 Prius. So I hope god of Prius give me at least one year and the price of used come down a bit.
