Overheat and coolant loss from reservoir, how to tell if water pump or head gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by QuinnVee, Jul 7, 2025.
  1. QuinnVee
    QuinnVee New Member
    Tucson, Az
    Hi there!
    A few weeks ago my 2012 prius (105k miles) overheated, while highway driving for a few hours in the 110 heat. I slowed down and the overheat light went away but the check engine light was on. The codes were po117 and p148f and there was spilled coolant on the reservoir. I refilled the coolant and it hasn't noticeably lowered but I have found marks in my driveway. I've had to drive it around town the last few weeks and it hasn't thrown anymore codes or overheated.
    I brought it to the dealership to see what they'd say and they recommended replacing the water pump and thermostat because of the codes and the spilled coolant around the reservoir.
    I'm planning on replacing the pump and thermostat myself ( and maybe cleaning the egr while I'm in there). Before I do so I want to find out if there are head gasket problems. What should I be looking for/ what tests should I be running. Torque shows no misfires on start up and the oil on the dipstick looks regular to me. I am fairly new to car stuff so any advice is wanted.
    Thanks!
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,747
    1,778
    Bay Area
    If it’s your headgasket, you can remove the spark plugs and put a borescope down there to see if the pistons top is wet or not. Also, you should have a leak in the coolant reservoir if it’s the HG
  3. T1 Terry
    T1 Terry Active Member
    929
    491
    Get a gas test on the coolant, if there is combustion gasses in the coolant, it's a head gasket, if not, put cardboard down under the engine and check in the morning just where the coolant leak is dripping from .... you might need to remove the plastic tray under the engine (if it still has one) and redo the drip test a few times to isolate where the problem leak is .... the water pump leak will appear at the fan belt end of the motor, easy enough to replace, unlike the gen 2, Google Search
    themzlab likes this.
  4. ASRDogman
    ASRDogman Senior Member
    7,844
    3,997
    That test doesn't work on the Prius because it's the coolant that leaks into the cylinders.
    Unless it's REALLY bad, but by then you won't need that test, you'll KNOW it's the head gasket
    and likely a warped head.
    There is no pulley on the Prius coolant pump.
    Brian1954 likes this.
  5. Brian1954
    Brian1954 Senior Member
    2,422
    972
    South Central PA, USA
    I agree with the dealership that you need to replace the engine water pump before you drive the car again. An OEM pump is preferred. Do not buy a cheap aftermarket pump on Amazon or eBay. They do not last very long, and you will end up having to replace it again.
    If you have a bad head gasket, you would get misfires (rattling) during cold startup of the engine. I do not think that you presently have a head gasket issue. The P0117 code indicates that the engine severely overheated. This can lead to the head gasket going bad 6 to 12 months from now.
    So, replace the water pump ASAP and consider a replacement car in 6 to 12 months if you do not want to deal with a bad head gasket.
    QuinnVee, NutzAboutBolts and BiomedO1 like this.
  6. Mendel Leisk
    41,953
    Considering water pump failure reports here, it's prudent replace the engine water pump and associated thermostat at 100K miles.
    The inverter water pump I think is similar construction? Likely best to replace that before long as well. To argue against replacement at the same interval: perhaps it's not used as much, or for some reason just lasts better. There don't seem to a lot of failures, at least not reported here. Also, it's a sandpounder to access.
    BTW: with over 100k miles, I'd do a full EGR system cleaning ASAP, see top two links in my signature. (on a phone turn it landscape to see signatures)
    QuinnVee likes this.
  7. BiomedO1
    4,226
    2,211
    SacTown, Ca
    FWIW: severe overheats can cause leaks in the seams of your plastic coolant overflow bottle. Your engines' normal operating temperature range is around 190F-215F and that overtemp. lamp goes off around 245F. You've overheated for a while to throw a P0117 - long enough for your ECU to think there was a temperature sensor issue.
  8. rjparker
    10,581
    6,637
    This is one of those times you do it now. You are close to having to replace the engine. Change the water pump with oem now.
    QuinnVee and BiomedO1 like this.
  9. QuinnVee
    QuinnVee New Member
    Tucson, Az
    Thanks everyone, I won't be driving the car until I change the pump.
    From what I've found Aisin is oem for Toyota. Is there any reason to buy a toyota branded one from the dealership over an Aisin one from RockAuto? (My account is too new to post links, sorry)
  10. QuinnVee
    QuinnVee New Member
    Tucson, Az
    Actually nvm, I'll get it from Toyota as it's only a little more expensive.
  11. themzlab
    themzlab Junior Member
    28
    Wisconsin USA
    This test worked on my HG leak. if coolant leaks into the cylinders it stands to reason gases will leak the other direction. The hole goes both ways. If the test is negative it doesn't prove your H.G is ok but it is a good test because it is simple and cheap. I know what others say about this but my leak was a minor situation and this gas test worked.
  12. Mendel Leisk
    41,953
    #12 Mendel Leisk, Jul 9, 2025
  13. ASRDogman
    7,844
    3,997
    99% of rockauto is chinese junk. If you buy it from Toyota, you know you are getting oem.
    How much is the price of a new engine, and labor, that seizes because the chinese copy coolant
    pump fails? Plus, leaving you stranded somewhere?
  14. NutzAboutBolts
    1,747
    1,778
    Bay Area
    I bought my aisin water pump on Amazon for 148$ with 7$ discounted coupon. It’s been working fine.
  15. Mendel Leisk
    41,953
    For me, the Aisin WPT 190 through Amayama is $131~132 USD (at current exchange rate), all-in. I’ve purchased 5~6 items from them, including oil filter conversion items, nary a problem.
  16. ASRDogman
    7,844
    3,997
    Ohh, so you are the "one"! (y):whistle::whistle:
    Just remember, even a broken clock is correct twice a day...
  17. adrtho4
    adrtho4 Member
    71
    26
    Houston, TX
    Get the Asin water pump! I bought a previous brand before. It didn't work and my engine overheated. I bought this exact same Asin pump, no issue. Get that Asin pump and accept no substitutes.
    Seriously... don't be like me and learn the hard way.
  18. QuinnVee
    QuinnVee New Member
    Tucson, Az
    Thanks for the advice guys. I did the swap last night and it went (mostly) great!. Seems to be running good today. I accidentally snapped the upper bolt that secures the dipstick while learning how to use the torque wrench (I was expecting more of an audible click instead of a dull release). I have attached a picture of where the bolt was. Any tips on getting it out and/or is it ok not being attached for now?
  19. Mendel Leisk
    41,953
    That's one of the 5 fasteners (2 studs/nuts and 3 bolts) clamping the intake manifold to the head. Torque on it is 21 ft/lbs. Hindsight is 20/20, but it probably wasn't necessary to remove it, and the dipstick guide tube.
    I'd get it remedied before driving, but maybe over OCD: the intake manifold is now missing one of it's 5 fasteners. It's very stiff, likely good, but if you drive I'd limit it to a short run to the dealership, to get the proper replacement bolt from dealership.
    Step one is to get the broken portion out. You can either carefully drill an appropriate pilot hole for a reverse-thread bolt extractor bit, or take the intake manifold off completely, which may afford you enough of the bolt remainder to grip, or dremel a slot on the end.
    If you take the intake manifold off, you likely could leave the throttle body and it's coolant lines attached, just lift everything off the studs and clear enough, don't escalate any further than necessary.
  20. QuinnVee
    QuinnVee New Member
    Tucson, Az
    Appreciate the advice and manual page Mendel, I'll take care of it today. It took a lot of willful stupidity to break it, summer in Tucson means working at night so I was dead tired hahaha.
