150k Mile Report – Restore & Protect Oil + BG44K = Real Results
Discussion in 'Gen 3 Prius Main Forum' started by TNPrius20, Jul 8, 2025.
  1. TNPrius20
    TNPrius20 New Member
    Nashville,TN
    Hey everyone,
    I wanted to share a full update on my experience using Valvoline Restore & Protect in my 2015 Prius (Gen 3), currently at 150,350 miles. I’ve been focused on long-term reliability and preventative maintenance, and this oil has delivered some real improvements.
    Background:
    Before switching, I was using Mobil 1 Extended Protection and averaging around 39–41 MPG. The engine had some cold start roughness and didn’t feel very smooth under load.
    At around 144,350 miles, I switched to Valvoline Restore & Protect 0W-20. I’ve now completed three full oil changes using R&P:
    • First change: ~144,350
    • Second change: ~146,850 (short 2,500-mile flush interval)
    • Third change: 150,350 (after a 3,500-mile run)
    Each change used a Valvoline oil filter, and I added BG44K after the second oil change.
    Driving Results:
    • Current MPG (after 3rd R&P change): 46.1 MPG on a normal commute
    • Previous average (on Mobil 1): 39–41 MPG
    • Improved average during R&P use: 42–43 MPG
    • Total MPG improvement: ~5 to 7 MPG
    • Oil consumption trend:
      • On Mobil 1: ~0.1–0.2 quarts every 3,000 miles
      • After first R&P: reduced to ~0.1 quarts
      • After second R&P: 0 quarts used over a 3,500-mile interval
    • Engine behavior:
      • Cold starts now completely smooth
      • Quieter idle
      • Stronger and more responsive throttle
      • Overall smoother engine operation with no rattles or vibration
    Other Maintenance Completed:
    • New KYB Strut-Plus front struts
    • Moog sway bar links (front)
    • Recently switched to Bosch QuietCast brakes
    • Planning upcoming work:
      • EGR cooler clean/swap
      • PCV valve
      • Intake manifold clean or replace
      • Engine water pump replacement
    Final Thoughts:
    Valvoline Restore & Protect has been a worthwhile switch. Fuel economy is up, oil usage is gone, and the engine genuinely feels healthier. If your Gen 3 Prius is in the 120k–180k mile range and you’re chasing better efficiency or trying to delay oil burning and head gasket concerns, this might be worth testing out.
    Let me know if you’ve tried it too or have questions about the process or results.
  2. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Great post! Focusing on longevity, when was the last time egr circuit was cleaned?
  3. ASRDogman
    ASRDogman Senior Member
    7,607
    3,915
    Changing oil won't effect cold starts or rough idle or throttle response.
    It really won't effect your mpg either, unless you were using 40w or 50w or higher.
    Which you shouldn't be doing anyways... buttttt.......
    The bg products don't really work either.
    Will it effect oil burning????? Mayyyybbeeeeeeee
    If you've been changing your oil every 5000 miles, not very likely.
    You have low miles, for a Prius. And with synthetic oil (you have been using synthetic oil?),
    the engine is going to be very clean.
    Now if you've been using non synthetic oil, then changing oil will effect how clean the engine is
    and possibly your mpg. Probably best to still with Toyota OEM oil filters...
    Perhaps your driving habit's have change. The fuel you use, and are you putting cleaner in the
    fuel also? That will effect the mpg.
    I've been using seafoam 500 miles before oil change, and I had used the bg products, NO change.
    And I started using the valvoline retore and protect since March 2024 at 330,277 Miles.
    Changing oil at 5000 miles, give or take a few hundred miles using RP.
    I am currently at 372, 200 miles. So 8 oil changes. I think I'm burning more oil now.
    You say you've only been getting 40 mpg???? That's horrible. Unless you do a lot of city driving
    or drive very fast for highway driving.
    42-39 is "3"
    43-42 is "2"
    That is not a 5-7 mpg improvement.
    Where are you getting 46mpg average from your information??
    Johnny Cakes likes this.
  4. Noahdoge
    Noahdoge Active Member
    202
    144
    Mississippi
    I’m excited to try the Valvoline R&P on my next oil change with a carquest premium oil filter (converted to spin on). I’m at 210k and burn 0.5-0.7 quart every 5k, so oil consumption isn’t bad but also not the best. I get about 45 mpg with majority highway driving.
    Jim Swart likes this.
  5. Noahdoge
    202
    144
    Mississippi
    I’m curious with your high mileage, how much oil consumption do you have per 5,000 miles.
  6. Eddie25
    Eddie25 Active Member
    497
    209
    MI
    I went from about a quart every 1k miles to 1/4qt every 10k miles by using B12 chemtool as a piston soak (which was 25k miles ago). I have been using R&P for the last 10k miles with no discernable effect. I would still recommend the piston soak to anyone dealing with extreme oil burning.
    mikey_t likes this.
  7. ASRDogman
    7,607
    3,915
    Unless you soak those pistons for ages, it is like snake oil.
    It takes a long time for the liquid to get through those oil rings, and then to actually clean them??????
    1-2 quartz depending on how I drive.....
  8. Eddie25
    497
    209
    MI
    I merely soaked for 14 hours overnight and I make no exaggeration. I did rotate the crank and refill the cylinders regularly while I was awake. Not claiming it will work for everyone but it worked for me.
    mikey_t likes this.
  9. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Unless you boroscope before
    And after each of the pistons and do
    A microscopic analysis of rhe oil filter and oil, I’ll chalk it up like asrdogman driving style change.
  10. ETC(SS)
    7,184
    Congratulations!
    How long have you been working for Valvoline?
    Grit likes this.
  11. ColoradoBoo
    ColoradoBoo Senior Member
    1,241
    833
    Monument, Colorado USA
    Yep, I now have three five-gallon cartons of Valvoline Restore and Protect in my garage for the family vehicles I serviced. (0W-16, 0W-20, 5W-30) So far, I've only done two oil changes but the numerous reviews I've seen on YouTube are impressive...one even took an engine apart to inspect it after using it for a while....VERY impressive with the cleaning abilities! (I'm, especially, excited to be using it in my daughter's Hyundai with that GDI engine which is known to gunk up and not last a long time.)
    mikey_t likes this.
  12. ASRDogman
    7,607
    3,915
    Seriously? I've got some waterfront property for sale really cheap you might be interested in.
    Cash, American, only! (y):whistle:
    Grit likes this.
  13. Jim Swart
    Jim Swart Member
    57
    Portland, OR
    Valvoline Restore and Protect 0W-16?
    Brian1954 likes this.
  14. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Bam!!!
  15. ETC(SS)
    7,184
    One step closer to my life goal of being quoted in @Grit 's signature!
  16. TNPrius20
    Nashville,TN
    Don’t work for Valvoline at all just sharing my results I’ve experienced. I’m not even in the automotive industry.
    Haven’t done the EGR clean or intake manifold yet. Not sure why it’s controversial to have results. I’ll chalk it up to being one of the few that has seen results early I guess. I don’t understand the need for the hostility.
  17. ETC(SS)
    7,184
    I'm not being hostile at all!
    I'm merely sharing MY experience.
    Brand new PC members who leave long and glowing reports that mention a product's full name three or more times are usually 'sharing their experience' as a sales person for that product.
    Either that or they are expressing the zeal of the newly converted.
    Don't be so thin-skinned.
    Results are often controversial.... ;)
    It even happens to people in politics.
    Then I'm a little curious about your stated focus which is: "long-term reliability and preventative maintenance."
    You have a ten-year-old Prius G3.
    It has 150,000 miles on the clock.
    In your "maintenance completed" column you mentioned struts, links, and brakes - and you're planning on replacing the water pump soon? o_O
    Your car doesn't even have a temperature gauge!
    How long have you had the car?
    When did you replace the plugs? (They were due at 120,000 for this car, IIRC)
    If your long term focus REALLY IS "long-term reliability and preventative maintenance" then I've got some GREAT news for you, and some not-so-great news.
    The great news is that your Warranty and maintenance guide AND this forum can get you to about 250,000 miles in this car!
    The not-so-good news is that there are two kinds of G3 drivers with over 100,000 miles:
    Those who need a new head gasket.
    Those who WILL need a new head gasket.
    Best of luck!
  18. Johnny Cakes
    Johnny Cakes Senior Member
    1,049
    780
    Virginia, USA
    1. Post Hoc Ergo Propter Hoc:
    2. See below.
    douglasjre likes this.
  19. ColoradoBoo
    1,241
    833
    Oh my bad, no the 0W-16 is just Full Synthetic. (I'm not worried about gunk in the newer Prius and Corolla, which are our only vehicles that use it.)
  20. ETC(SS)
    7,184
