Why is my hybrid battery draining?
Discussion in 'Gen 2 Prius Technical Discussion' started by speedway dave, Jul 8, 2025.
  1. speedway dave
    speedway dave Junior Member
    Indy
    all. Haven't been here for a while b/c 2004 w/198k miles has been running fine. I cleaned out the hybrid battery fan last week after seeing some YT videos. Drove around until the battery was charged 3/4 and didn't see a difference in fuel mileage (I don't remember the last time I saw it fully charged).
    Parked it for the long weekend and this morning the display had only one pink bar. Drove it around until about 3/4 charged. Parked in the driveway about 4 hours ago, and now the battery has only 3 bars. Fuses all look OK. No red triangle. Any ideas what is causing this? TIA
  2. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    Your battery has lost its capacity.
    Brian1954 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    12,964
    5,275
    Pacific Northwest, USA
    Everything is normal... NiMH batteries self discharge when sitting unused so multiple days or weeks on an older pack becomes problematic because cells will self discharge at different rates and that can lead to red triangle and system shut down. Using a high voltage trickle charger is the solution. Maxx volts and Hybrid Automotive sell them. There some on Amazon too that are general purpose high voltage low amp chargers too. You can also build your own: Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    Once you have a charger you can periodically charge and balance the pack, especially after it's been sitting for a long time. Also you can extend your pack's lifespan by doing reconditioning too. In general the instruction on hybrid automotive website are the best for telling you how to do everything and how it works, but their equipment is buggy and way too expensive: FAQ - Hybrid Automotive
  4. Carall
    316
    104
    Harrisonburg, VA
    The 21-year-old battery with 200k miles will likely needs to be cycled every 12 months or even sooner.
    During the first reconditioning, it is necessary to discharge the battery below 84 volts, since the battery pack most likely already has cells in the modules that are worse than the rest.
  5. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    A 21 year old battery with 200k miles? You already know the answer.
  6. PriusCamper
    12,964
    5,275
    OP never indicated that it was the original battery... Only that the battery was working near normally.
  7. frodoz737
    4,711
    2,513
    33
    Thanks, but my answer was based on the info given. Give more info and my answer may change.
  8. Carall
    316
    104
    Harrisonburg, VA
    If you don't have a few thousand dollars for a new battery, but you have a couple hundred dollars for a charger and a discharger, and you're a DIY kind of person, then why not restore the capacity periodically over the next few years?
  9. PriusCamper
    12,964
    5,275
    No it was not... You made the assumption that car still has it's original pack when OP didn't indicate vehicle pack history at all. Almost everyone who hasn't bought brand new has not look at the serial numbers of their 28 pack modules to determine date of manufacture and if it has a history of being rebuilt or not. An essential step in evaluating a pack's lifespan.
  10. frodoz737
    4,711
    2,513
    33
    Not sure your issue here. OP made statements and asked questions. I made no assumptions outside of the facts given and responded based only on the information provided. Relax.
  11. speedway dave
    Indy
    Most helpful reply. My concern was that I have never seen it discharge so quickly, although I normally use the map or mileage screen so maybe haven't noticed. I've been all over this car except for the hybrid systems, and after some research I have some good ideas what I need to do. Just have to find the time for the reconditioning since this is my every-day car. Thanks for all the info.
  12. PriusCamper
    12,964
    5,275
    In that case you're gonna wanna watch some youtube videos on how to pull the pack and clean/replace the corroded parts. The link in my signature gives a 10% discount on voltage sensor wires which tends to allow corrosion from battery terminal to get into hybrid battery ecu pins. There's a pin in there that grows corrosion and screws up the data signal leading to a sudden drop down to two bars on screen even though the pack hasn't actually lost that charge. But because car thinks battery needs charging it can overcharge it and cause damage if you're pushing enough amps.
    I wouldn't worry about the reconditioning until later on, once you know pack and ECU is clean, as well as figured out date of manufacture of each of the 28 modules via serial numbers on them.
    gdanner likes this.
  13. speedway dave
    Indy
    Thank you for the additional info. I will certainly check them and hit you up for new ones if needed.
