1. pasadena_commut
    pasadena_commut Senior Member
    2,279
    679
    Southern California
    It feels like our 2007 is warming up slower, often taking an extra 5 minutes or so before the MPG bars show best efficiency. Which is unexpected because it has been quite warm lately, often near 90F, and naively one would expect that to result in faster ICE warm ups. So maybe not an ICE warm up issue.
    I may be hallucinating about this, and it could represent something environmental, like changes in driving patterns. There has been a lot of stop and go with the A/C on, for instance. But for the sake of argument, if there was a problem, what should I look for in Techstream? Coolant temperature, pack temperature, something VVT related? No CEL is lit.
    Thinking about the pack temperature as a possibility because the car is parked in the sun, and it might take a long time for the A/C and pack fan to cool the preheated pack down to a temperature where it works better. The other day I looked at that with Torque and pack T2 was 105F at the moment the car turned on and then with A/C on it quickly went to 107-108, it had not come down much in a couple of minutes sitting in the driveway. Better cooling when moving than sitting still, of course.
    Edit: just checked again with Torque and no error codes. It is earlier in the day and battery T2 at startup was 87 which is only a little more than ambient of 85. Windows in car have been open since the sun came up, last time it was early afternoon and the windows had been closed.
    #1 pasadena_commut, Jul 9, 2025 at 2:24 PM
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Your High Voltage battery provides lots of energy to the AC system and in super hot weather the computer will send less High Voltage power for AC use so the battery drains slower.
    But that doesn't explain what you're correct in calling a hallucination because you're using MPG bars to diagnose engine warmup temp and those mpg bars are an approximation of lots of different factors. For example, just a little less air in one of your tires could change that measure of efficiency.
    If you want to watch your engine coolant temp or pack temp buy an OBD2 bluetooth reader to connect your car to your phone so you can run apps that will give you that data.
  3. pasadena_commut
    2,279
    679
    Southern California
    I can watch those values with Torque on the Android phone and the OBD2 dongle.
    Is there a way in Techstream to "dump everything" into a text file? What I'm after is "the complete state of the car, now". That is, all the current live values and the results of the most recent readiness monitor tests? I know how to watch live values for one ECU, but to gather all the data requires a lot of clicking and selecting. Torque can log a list of selected values, but they need to be entered one at a time, which is again a whole lot of clicking to set it up.
  4. PriusCamper
    12,064
    4,896
    I don't think techstream is that sophisticated unless you found a way to write a bunch of scripts to do that. But one time I went on a 2 mile drive using Hybrid Assisstant app with its companion app Hybrid Reporter and when I got home I had 20 pages of really cool charts and data of how that drive went. So I'd start there first and then use Techstream to get more details on anything specific you're concerned with.
  5. pasadena_commut
    2,279
    679
    Southern California
    Searched a bit and maybe the "store all data" option when checking the ECUs would do most of this? Unclear if there is an option to dump it all to a text file though.
  6. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    Save your session at the end. The saved file is a CSV with everything that Techstrwam recorded.
